BILSTEIN ADJUSTABLE LIFT KIT WITH 5100 SHOCKS
Discussion in 'Suspension' started by redtacoma88, Aug 8, 2013.
  1. Aug 27, 2013 at 3:14 PM
    #41
    rockgecko03
    rockgecko03 Well-Known Member
    Ben
    Rockwall, TX
    1999 Tacoma - Perpetual Project
    It is true, the 5100's don't preload the spring the same way a spacer lift does. However, that does not mean that they don't preload the spring. They just do it a different way.
  2. Aug 27, 2013 at 6:29 PM
    #42
    whonoez
    whonoez Well-Known Member
    Jay
    Bay Area
    2013 Tacoma TRD Sport DCSB
    3"lift, Monster XD w/ 285/65/18 Nitto Trail Grapplers, Blacked out emblems, tinted front windows, BHLM
  3. Aug 27, 2013 at 6:58 PM
    #43
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    If you have 4 leafs in the rear that means you have the TSB leaf pack....make sure you order the AAL that goes with the TSB leaf pack. Other than that you shouldn't need anything else besides what come with it....maybe extended u-bolts but that's it.
  4. Aug 27, 2013 at 7:13 PM
    #44
    whonoez
    Jay
    Bay Area
    Cool thanks!!
  5. Aug 28, 2013 at 7:44 AM
    #45
    ptluke
    ptluke Member
    Utah
    2012 TRD Sport Longbed Tacoma
    Hey, thanks for your help on this!
    So are these kits essentially what I would be putting together with the parts list you have advised? (minus the bilsteins on the OME's package)
    And the AAL (even though I believe I already have the 4 leafs in the back) would be the way to go over the Blocks? Do I need to invest in new UCA's as well?
    http://toyteclifts.3dcartstores.com/Bilstein-Adjustable-lift-kit-with-5100-shocks_p_132.html
    http://toyteclifts.3dcartstores.com/OME-Tacoma-Suspension-lift-kit_p_231.html
  6. Aug 28, 2013 at 7:45 AM
    #46
    ptluke
    ptluke Member
    Utah
    What type of truck do you have? I have a 2012 Sport DCLB.
    Lemme know how your install goes with that package, im looking at something like that as well!!
  7. Aug 28, 2013 at 9:36 PM
    #47
    whonoez
    Jay
    Bay Area
    I have a 2013 DCSB TRD Sport 4X4. I placed my order last night. Ordered that lift kit with rear tsb leafs and LR UCA's with the U Bolt flip kit. Gonna order tires tomorrow. Nitto Trail Grapplers M/T 285/65/18. I'll def post some pics when I'm done with all the installation.
  8. Aug 29, 2013 at 6:47 AM
    #48
    rockgecko03
    Ben
    Rockwall, TX
    Essentially, yes. However, I wouldn't buy/install the diff drop or buy it as an entire kit. It costs a little less if you buy the parts individually.
    Another install option is to have them preassemble the coilovers. If they do that all you have to do is literally unbolt the front end, pull out the old, put in the new, and bolt it back up.
    For those of you buying from Toytec, be sure to use your TW discount code for 5% off.
  9. Aug 29, 2013 at 7:50 AM
    #49
    lightinglark956
    lightinglark956 Well-Known Member
    pat
    springfield il
    2012 tacoma trd offroad
    k&n cai ,flowmaster series 40 single in dual out with custom dual exhaust out the back with 4 in ss cans ,backflip vp tonneau Blackhorse stainless bulbar ,35% tint front and rear,rainguards ,glovebox console organizer,ome 887's ,Dakar rear leaf package ,ome nitro charger schocks ,lr uca's ,diaz devil horn emblem,goodrich ext brake lines
    hey guys I just want to level my 2012 dbl cab short bed 4x4 trd off road can I just put all 4 5100's and adjust the fronts to .85 or 1.75 ? would I need to realign the front end ? kinda went over budget on the kn 63 series cai and custom dual exhaust out the back ? any suggestions don't do much off road but looking for level better riding thanks
  10. Aug 29, 2013 at 8:19 AM
    #50
    rockgecko03
    Ben
    Rockwall, TX
    Yep, all you should need is the shocks. I'm not sure if you need the lean spacer if you're staying with the stock springs. If all you're doing is leveling out the front to match the rear, you don't actually need to get the rear shocks. However, they are a nice upgrade over the stock setup.
    Yes, you will need an alignment afterwards.
  11. Sep 5, 2013 at 10:20 AM
    #51
    erotic dad
    erotic dad Member
    Loud City
    13 DCSB TRD OR
    Just bumping this very informative thread because these are the only questions I have left about my lift as well. For context, I'll be going with Bilstein 5100s all around set to 0 and OME 885 coils with a 1/4th" lean spacer. Only remaining questions are those quoted above. Thanks!
  12. Sep 5, 2013 at 11:43 AM
    #52
    rockgecko03
    Ben
    Rockwall, TX
  13. Sep 5, 2013 at 7:50 PM
    #53
    ViperACR
    ViperACR Active Member
    Kansas City
    13 TRD Sport
    I have a 13 DCSB with the TSB springs already in place. I am doing 1.5 AAL. Do I need to order extended U bolts?
  14. Sep 6, 2013 at 6:52 AM
    #54
    rockgecko03
    Ben
    Rockwall, TX
    No, you're stock u-bolts should be fine. Mine were anyway.
  15. Dec 16, 2013 at 5:15 AM
    #55
    Tacoma VT
    Tacoma VT Well-Known Member
    R. Kessler
    Vermont
    10 DCLB TRD sport
    OME 884s, Bilstein 5100 Shocks, Icon 3 leaf progressive AAL (with overload in), Rear leaf TSB, ImMrYo mirror relocater, ARE Z series cap, Hi Lift jack W/ DIY mount, trimmed Mud Flaps, Devil Horns by Andres, EGR In-Channel rain guards, LED bed lights, Weather Techs
    This helped. Thanks man.
  16. Dec 16, 2013 at 5:40 AM
    #56
    !TacoTaco!
    !TacoTaco! TACO LOVER!
    Felix
    PSL, FL
    09 Prerunner TRD SR5 Sport
    Removed coal filter, Also installed AFE air filter. Roof rack with custom diamond plate air diverter.
    Subd for later use!
  17. Dec 26, 2013 at 1:58 PM
    #57
    SpeedwayTaco160
    SpeedwayTaco160 Well-Known Member
    Killeen TX
    10 Sport SWB DCSB
