Bilstein and curb weight correlation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco Slinger 4000, May 23, 2018.
  1. May 23, 2018 at 12:12 PM
    Taco Slinger 4000
    Taco Slinger 4000 [OP] Active Member
    Volusia County FL
    2016 White Tacoma sr5
    A 2016 sr5 4x2 4cylinder acess cab has a curb weight of 3980lbs. A 2011 prerunner 4x2 6cylinder double cab has a curb weight of 3975lbs.
    Both tacomas have the same curb weight +-5lbs.
    Will the bilstein 5100 set at .85 lift both of these trucks the same amount of distance from center cap to fender?
  2. May 23, 2018 at 1:25 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    hint, shocks don't lift, springs do. But given the same springs, seems pretty logical.
    addition: this is assuming that the mount points of the shocks and pivot points are the same between the 2nd and 3rd gen. I don't have the data for that.
    hiPSI likes this.
  3. May 23, 2018 at 2:29 PM
    Taco Slinger 4000
    Volusia County FL
    That’s what I was missing in my thought process..more than likely the pivot points are also different
