Bilstein B12 vs Eibach 14” 650 springs
Discussion in 'Suspension' started by renval, May 5, 2022.
  1. May 5, 2022 at 12:23 AM
    renval
    renval [OP] Well-Known Member
    Renz
    SoCal
    Planing on changing the 13” 650 springs that came on my Icons, so you know the difference between this two, I can’t find the specifications on the B12 special suspension #53-291387 springs.
  2. May 6, 2022 at 7:30 AM
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    I am not familiar with the Icon Springs but the Bilstein 650# spring is 14". Not sure what the difference would be when compressed with weight. Is that the info you are looking for or did you need more?
  3. May 6, 2022 at 1:04 PM
    renval
    Renz
    SoCal
    I went with the B12 springs, the guys from Shock Surplus suggested to get this one over the Eibach 14” 650 lbs, they said is the same spring specifications, the only difference is the B12 come in black and the price is way lower than the Eibach.
  4. May 16, 2022 at 8:34 PM
    Mtntac2145
    Mtntac2145 Member
    I can tell you the Eibach springs will hold there spring rate longer. I have run Eibach on my tacoma with bilstein 5100’s and on my dirt late model with Ohlins shocks and they are some of the best springs you can get . The spring rate stays very consistent over the life of the spring and they can take a beating and hold up.
