bilstein front 5100's with camper shell tsb?
Discussion in 'Suspension' started by Dsmooth87, May 29, 2012.
  1. May 29, 2012 at 7:31 PM
    Dsmooth87
    Dsmooth87 [OP] Well-Known Member
    11' doublecab 6spd 4x4 trd offroad
    Satoshi Grille. 245/75r16 hercules terra trac a/t. Afe pro dry s. ome 884s toytec 1.5 AAL for TSB. Twm shift knob
    My truck is a 2011 4x4 4 door sb with a camper shell with tsb leaf springs and i currently have a rake. i want to level the truck out but not sure if i should go .85 or 1.75 because i feel the shell may require less lift to level the truck out. any opinions?
  2. May 29, 2012 at 7:35 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. But just take a tape measure to the front fender and us that to get some kind of idea where the truck will sit after installing the 5100's. What size AAL is it...1.5"...2"? If its a 2" AAL, most people lift to 2.5"s but the back is normally a little higher still but with your camper shell it might sit just level.
  3. May 29, 2012 at 7:35 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Whats the difference in height between teh front and rear?
  4. May 29, 2012 at 9:58 PM
    Dsmooth87
    rear sits about inch an half higher
  5. May 29, 2012 at 10:16 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Won't the TSB springs settle with wear?
    I actually like a little rake. Last thing I want is squatting when I put a load on the back end.
  6. May 30, 2012 at 6:03 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    For 1/2", just go with top plate spacers up front. The 1/4" thick spacer will do the trick.
