Bilstein help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stormtrooper37, Dec 13, 2011.
  1. Dec 13, 2011 at 6:25 PM
    stormtrooper37
    stormtrooper37 [OP] Nutts
    Tyler
    Baltimore MD
    Toytec 2.5 Bilsteins Tint Rims Tires Exhaust
    Ive got a 2.5 toytec lift how high can i set my bilsteins without causing damage ?
  2. Dec 13, 2011 at 6:28 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Just set the 5100's at 2.5 and ditch the spacer. DO NOT USE BOTH!
  3. Dec 13, 2011 at 6:29 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Don't use the spacer lift with the 5100 (I'm guessing you have purchased), stacking lifts WILL cause damage.
  4. Dec 13, 2011 at 6:30 PM
    Large
    Large Red
    Set at 0 for no damage. Use search, there's approx 10,944,843 threads on bilsteins.
  5. Dec 13, 2011 at 6:32 PM
    Pugga
    Massachusetts
    You're far less likely to cause damage setting the Bilsteins at 2.5 vs. using a 2.5" top plate spacer.
  6. Dec 14, 2011 at 4:14 AM
    stormtrooper37
    Tyler
    Baltimore MD
    will it be a smoother ride then the top plate spacer ? and will i lose any height ?
  7. Dec 14, 2011 at 5:05 AM
    Large
    Large Red
    The OP said nothing about top plate spacer. Since he said 2.5" lift I assumed he meant he had 5100s.
  8. Dec 14, 2011 at 5:32 AM
    Pugga
    Massachusetts
    You purchased adjustable shocks, use them for a lift. Top plate spacers have a range of potential issues. It will ride stiffer because you're preloading your coils but the 5100's will do alright to dampen the ride. You will not lose any height.
    He said he has 5100's and a 2.5" lift from Toytec. To me, that means he has a 2.5" top plate spacer :notsure:
  9. Dec 14, 2011 at 7:11 AM
    stormtrooper37
    Tyler
    Baltimore MD
    yea i have a toytec 2.5 imch lift aal in the rear and the spacer up front i have not installed the bilsteins yet.
    so i SHOULD remove the spacer and set the bilsteins to 2.5 ?
  10. Dec 14, 2011 at 7:29 AM
    Pugga
    Massachusetts
    I would use the Bilsteins set at 2.5 rather than the spacers and this is why...
    http://www.camburg.com/toyota/00-06-tundra/read-before-buy-spacer-lift/
    If you have a TRD Off Road, preloading the coils to 2.5" would make them very stiff as they are a progressive coil. The TRD Sport and SR5 use linear coils and they will still be stiff, but not as bad. Best case, you sould get replacement coils to lift 2.5", 5100's at 2.5 would be my next choice and the spacer would be my last choice.
  11. Dec 14, 2011 at 7:35 AM
    stormtrooper37
    Tyler
    Baltimore MD
    ok thanks a lot
