Bilstein help!!!!
Discussion in 'Suspension' started by tacomakid96, Mar 12, 2010.
  1. Mar 12, 2010 at 8:36 PM
    tacomakid96
    tacomakid96 [OP] Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    I am going to purchase Bilstein 5100's but cannot find them on the internet, is there any place that any of you guys know that will have them? Also once I get them I will set them to 2.5 and want to know how big of a aal I will need to level out the back "a product link" would be helpfull. And lastly would a 32'' tire rub with a 2.5 lift? Pics would be greatly apreciated. Thanks
  2. Mar 12, 2010 at 8:42 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
  3. Mar 12, 2010 at 8:51 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    the reason you cant find them is because they are on backorder. down south had some, IDK if they still do. call them up, otherwise your gonna have to wait a few weeks
  4. Mar 12, 2010 at 8:53 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    here are some good AAL options
  5. Mar 12, 2010 at 9:00 PM
    tacomakid96
    Phil
    Out n' about
    Thanks ya down south is back ordered now to. With the 1.5'' aal set would that level the truck out? About how many total inches would my truck be lifted?
  6. Mar 13, 2010 at 8:13 AM
    tacomakid96
    Phil
    Out n' about
  7. Mar 13, 2010 at 8:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I think you would need to lift the front 2.5" to keep it level with the 1.5" AAL
  8. Mar 13, 2010 at 8:38 AM
    tacomakid96
    Phil
    Out n' about
    Ok and would I be able to run around a 32's or just stick with 31's?
  9. Mar 13, 2010 at 8:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should be fine with 32's
  10. Mar 13, 2010 at 2:19 PM
    tacomakid96
    Phil
    Out n' about
    Ok thanks If anyone on here has some pics of their first gen bilstein setup pictures would be very helpfull. :D
  11. Mar 14, 2010 at 9:00 AM
    R.etheridge
    R.etheridge Well-Known Member
    Middle GA
    03 Tacoma TRD 4x4
    I put a skyjacker 2.5-3 in lift on my 98 4x4 with yoko geolanders AT tires 32x12.50x15 and they fit. I just couldnt cut my wheels too hard or it would scrub the top wish bone, A arm, upper control arm, whatever you wanna call it. 1/2 wheel spacers, I was told would have taken care of the problem.
  12. Mar 18, 2010 at 4:33 PM
    Riderx805
    Riderx805 Well-Known Member
    Thousand Oaks, Ca
    08 PreRunner Double Cab
    *Pioneer In Dash DVD Player *Aftermarket Trailer Hitch *Bilstein 5100's w/ rear block *5% tint
    If you are going to set the bilstein's at 2.5 you may wanna consider getting some UCA's for the truck. I just got mine installed and my truck wonders a little when driving on the freeway. Also, even thought my truck was aligned right after the install, it still pulls to the left a little.
  13. Mar 18, 2010 at 4:41 PM
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
    yes yes no yes.... wait what?:rolleyes:
