Bilstein install help
Discussion in '1st Gen. Tacomas (1995-2004)' started by mike92y, Nov 9, 2010.
  1. Nov 9, 2010 at 6:37 AM
    mike92y
    mike92y [OP] Well-Known Member
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    OME all around. SPC UCA. This and that.
    I am going to be installing Bistein shocks all around on my 1997 Tacoma. I have a question concerning the front struts. When my Bilsteins were delivered they have a ring on the upper shaft just bellow the lock nut washer. What is this for? Sorry no pictures I am not smart enough to do that. I am doing the following install this weekend.
    Bilstein 5100's all around
    OME 881 coil overs
    Wheelers 5 leaf
    Rear brake pads hard ware and all that (I have to bleed the brakes for the longer rear brake line anyways and the wheels will already be off).
    I baught all new bolts and shackles. I have access to a Maintenance bay and an Impact wrench all all that jazz. Should be a good time.
  2. Nov 9, 2010 at 6:59 AM
    JBear
    JBear Spiral Out... Keep Going!
    Orange County, CA
    2003 Extra Cab 5 spd 4x4 TRD Off-Road
    2" suspension lift with King Coilovers up front. Standard Bilsteins on rear with a Fabtech 1.5" AAL. Leer 100XL Shell.
    All at once? Nice... you're gonna have a good time! I dont have 5100's yet, so I'll leave that question to a pro.
  3. Nov 9, 2010 at 7:10 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    hard to say without photos...
    one tip i suggest is to hit all the bolts, nuts, etc. (anything that'll be coming off or being loosened) a couple times with some penetrating oil like pb blaster starting 24 hours before you start the tear down and install. if your 97 is anything like my 2000 was, it'll make your life so much easier. :)
    good luck with the install!
  4. Nov 9, 2010 at 7:24 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Is it the ring that goes on top of the bushing?
  5. Nov 9, 2010 at 5:30 PM
    mike92y
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    I figured it out. It is the dust boot cover ring mount for the dust boots that do not come with the struts. I started to spray wd40 on everything a week ago. Every couple of days I spray it all down. I guess this will be a pretty big project. But I have a maintenance bay to work in and a impat wrench jack stands and all the tools I need. I like a challange.
  6. Nov 10, 2010 at 11:03 PM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    I wish I had thought of that before tearing apart my suspension tonight... spraying the hardware down with wd40 5 minutes before disassembly is definitely not enough time.
