Bilstein lift kit vs OME suspension lift kit?
Discussion in 'Suspension' started by thedude, Mar 8, 2011.
  1. Mar 9, 2011 at 6:24 PM
    #41
    wrecklesstacoma
    wrecklesstacoma Member
    Bill
    Oregon
    05 toyota tacoma
    stock
    I went with the 5100's up front and an aal in the rear, I achieved the overall look I was going for and since I am not an avid off roaded the minor stiffening isn't really an issue for me. That being said I will probably eventually buy the eibachs for the front so that when I do go off road the ride will be better. I am still a newbie but I thought I would throw in my $.02
  2. Mar 9, 2011 at 6:56 PM
    #42
    crawldad
    crawldad Well-Known Member
    2016 TRD OR 4X4 Quicksand
    I thought this thread was about Bilstein vs OME lifts. Not some cheap spacer lift.
    @Bnavillus likes this.
  3. Mar 9, 2011 at 7:01 PM
    #43
    thedude
    thedude [OP] Well-Known Member
    Lucas
    Little Rock, AR
    Well I assumed the cheap spacer lift was out of the question due to a crappy ride. Some don't think the Revtek's have that bad of a ride, but it obviously isn't as good as one with the full kits from people who have had both. Guess it depends on budget and tolerance of a "rough" ride.
  4. Mar 9, 2011 at 7:10 PM
    #44
    crawldad
    Yeah budget does play a part. But from my experience it costs more to take the less expensive route because you end up paying to do it twice once you realize its not what you really wanted. It's better just to do it right the first time.;)
  5. Mar 10, 2011 at 4:21 AM
    #45
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    thanks for the info, revtek employee. :rolleyes:
    and what about all of the procrap 3" and 6" lift kits the dealers buy from dealer services that have ties to 4WP?
  6. Mar 10, 2011 at 8:41 AM
    #46
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    EXACTLY! That was my mistake, blew 300 on that stupid ready lift :rolleyes:
    Live and learn huh? and if you can, learn from others as well. :D
  7. Mar 10, 2011 at 8:48 AM
    #47
    adamw
    adamw Well-Known Member
    sunnyvale, CA
    06 prerunner-> FJC 4x4 swap
    thats what i was looking into last night its about $100 cheeper to do it that way with all the same parts. if you dont have a DC do you still get the lean or am I safe with an AC?
  8. Mar 14, 2011 at 2:18 PM
    #48
    thedude
    Lucas
    Little Rock, AR
    Double checking, you need a diff drop on a 4x4, but not on rear wheel drive?
  9. Mar 14, 2011 at 2:41 PM
    #49
    Tythias
    Tythias Active Member
    Diff drops don't do anything for a 2nd gen tacoma. There are more negative effects with installing them. You can search this site and read about it.
    2wd trucks don't have a front differential so they cant use the diff drop :)
    Hoseman likes this.
  10. Mar 14, 2011 at 3:03 PM
    #50
    thedude
    Lucas
    Little Rock, AR
    OK thanks, this is why I'm confused - When you add the OME lift kit from the toytec site it gives you the option for a diff drop kit and says 4x4 (2wd no diff drop) so it implies you need it for 4x4. It also gives an optoin for top spacers for a full 3" lift, I assume this is a different type of spacer than the ones that compress springs and make a rough ride so I can add these or stay away? Thanks for the help. Just want to order the right stuff.
  11. Mar 14, 2011 at 4:40 PM
    #51
    Tythias
    The top plate spacer basically pushes the entire strut assembly down.
    This type spacer will not give you a rougher ride for the lift height it is designed for.
  12. Mar 14, 2011 at 5:08 PM
    #52
    thedude
    Lucas
    Little Rock, AR
    Thanks for the info, I obviously don't know crap about this but I'm going to get the OME kit and have it installed locally. I don't want a rough ride, not worth saving a few hundred to me.
  13. Mar 21, 2011 at 3:59 PM
    #53
    thedude
    Lucas
    Little Rock, AR
    After doing some more research it looks like you really do need upper control arms if you don't want your alignment jacked. Now I see why spacers are popular your talking over a grand to have a lift done "the right" way. May just do Bilstein 5100's.
  14. Sep 24, 2011 at 7:09 PM
    #54
    ckblum
    ckblum Well-Known Member
    Cam
    Chilliwack, BC
    Tacoma
    Bilsteins, Light Racing UCA's, Alcan's, Kragen HID's
    Honestly if you don't like the price don't lift it. It's like asking for 350hp+ but still wanting to get 30mpg, oh and you only wanna spend $500.
    I had a 3" spacer lift on my Tacoma and it could've still used a set of aftermarket UCA's so doing a spacer vs strut lift should still have the caster corrected. Do it right with the Bilstein's or OME and if you don't mind the way it's aligned leave it. If it bugs you spend the extra cash and fix it properly. Like stated earlier, you have a nice truck, don't cheap out on one of the most important parts of it.
    Lumberjackcoma likes this.
  15. Aug 8, 2012 at 6:51 PM
    #55
    BOONDOCKSAINT
    BOONDOCKSAINT Well-Known Member
    Central Louisiana
    WHITE 2016 DC OFF ROAD 4X4
    Pioneer 400w amp Infinity Reference Ref 6x9 (front doors) Infinity Reference Ref 6 1/2(rear doors) Kicker HS 8" hideaway
  16. Oct 11, 2012 at 3:12 PM
    #56
    nate08
    nate08 Well-Known Member
    Nate
    South Carolina
    Nate's '12 SR5
    So OP what did you end up doing? read the whole thread and it just ended without a closure. I'm in the same boat either OME or 5100's ordering today most likely. I think I'm going to cheap out on the UCA's for now. Hope that's not a terrible decision.
  17. Jan 21, 2013 at 9:51 PM
    #57
    jslum
    jslum Well-Known Member
    jason
    SoFL
    Sorry about bringing up an old thread but figured that was better than a new one. so with the above setup would you not need a sway bar relocate or rear shims? just trying to clarify.
  18. Jan 24, 2013 at 8:49 PM
    #58
    little squirt
    little squirt 808 ALLDAY!!
    808 ALLDAY!!
    im in the same boat, will the OME kit let you run 285's? any pics of this setup?
  19. Jan 25, 2013 at 4:26 AM
    #59
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    So with either of these kits you need a set of UCA's to align? What can not be set right without?
  20. Jan 30, 2013 at 10:41 AM
    #60
    Hippynotions
    Hippynotions Active Member
    Im going to go with the 2" lift from OME and it seems like a person needs new UCA's http://downsouthmotorsports.com/i-5...5-current-uni-ball-upper-control-arm-kit.html something like this or total chaos UCA's any other brands out there worth purchasing? Give me a shout back if you have installed new UCA's with your lift and it seems definitely worth it since it will correct everything and make the lift last a lifetime as well as the rest of the front end suspension components.
