Bilstein Lift Options. Help me out here.
Discussion in 'Suspension' started by ryank 5, Dec 4, 2011.
  1. Dec 4, 2011 at 7:24 AM
    ryank 5
    ryank 5 [OP] Well-Known Member
    Jefferson County, PA
    2006 Radiant Red Taco - Access Cab 4WD TRD
    OME Dakars, OME 884's, 5100's all around (0" setting), SPC UCA's, 17" 4-Runner Trail Edition Wheels with Dynapro's, ABS Killswitch Mod, Extang Tonneau
  2. Dec 4, 2011 at 7:31 AM
    CanisLupus
    CanisLupus Well-Known Member
    Ashburn | VA
    '11 Toyota Tacoma - '17 Yamaha FZ-09
    If you have the Toyota Rear Leaf TSB, you should get the 1.5''. If you do not, get the 2'' leaf option.
  3. Dec 4, 2011 at 8:46 AM
    ryank 5
    i don't think i do. does that mean you already have 4 leafs? because i only have 3
  4. Dec 4, 2011 at 8:49 AM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    You have the non-TSB packs. (if you are counting all the leaves, including the shorter overload leaf)
    Get the 2" non-TSB AAL from ToyTec if you want to lift that amount.
  5. Dec 4, 2011 at 8:55 AM
    ryank 5
    Thanks alot!
  6. Dec 4, 2011 at 9:07 AM
    jflan
    Vancouver, WA
    Edit:
    Clarification, see my last post.
  7. Dec 4, 2011 at 12:25 PM
    ryank 5
    it's 3. again thanks. and what's the highest i can go on the front without doing any damage to it?
  8. Dec 4, 2011 at 12:26 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
  9. Dec 4, 2011 at 12:34 PM
    ryank 5
    i'm confused. what's the range of the heights? highest and lowest
  10. Dec 4, 2011 at 12:40 PM
    OZ-T
    Peter North
    British Columbia
    0 , .85 , 1.75 , 2.5
  11. Dec 4, 2011 at 12:44 PM
    OZ-T
    Peter North
    British Columbia
    Are you 4x4 or 2wd OP ?
  12. Dec 4, 2011 at 1:13 PM
    ryank 5
    4x4. is 0 the highest or lowest?
  13. Dec 4, 2011 at 1:17 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Lowest
  14. Dec 4, 2011 at 1:21 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You asked what's the highest you can go without doing ANY damage. If you don't want to risk any premature wear and tear on suspension and driveline components, OZ was telling you to stay at the 0 or stock setting. Although he was being a bit of a wise ass, he's correct. Anytime you lift a vehicle and change the angles that the driveline operates at, you run the risk of introducing vibrations or premature wear of certain components.
  15. Dec 4, 2011 at 1:21 PM
    OZ-T
    Peter North
    British Columbia
    0 is the lowest .
    0 , .85 , 1.75 , 2.5 inches of lift respectively
    You can put it up to 2.5 , many people running that height on here , in fact you can add top plate spacers and get a true 3" .
    My comment that 0 is the highest you can go without damage is just that as soon as you lift at all above stock height you assume some risk for prematurely wearing out front end components such as CV's and the front diff .
    You may not have any problems , but then again you may .
    EDIT : Damn your quick fingers Pugga
  16. Dec 5, 2011 at 6:29 AM
    ryank 5
    ok i see. but can i put it at 2.5 when i'm just driving on the road? that would'nt do anything would it? and i could move it down if i were to go off roading? and would a top plate spacer change the quality of ride?
  17. Dec 5, 2011 at 6:38 AM
    ryank 5
  18. Dec 5, 2011 at 6:45 AM
    acdronin
    acdronin Well-Known Member
    OZ is correct and one other thing to keep in mind, there is a limit to how high you can lift the front before you run into alignment issues, in doing my research here and asking around, i was advised to install the front struts set at no higher than 1.75, which i did and had no issues with the alignment, i do however have a periodic hum from the front differential because i altered the geometry of the suspension, this would be the premature wear that everyone is talking about. For me it is a tradeoff because i had to fix and lift the back to handle all the weight i normally haul.
  19. Dec 5, 2011 at 6:51 AM
    Pugga
    Massachusetts
    F-150 Mod
    :D
    Traveling, including every day driving with the front lifted brings the potential for premature wear on certain components. Like OZ-T said though, plenty of people have lifts and do not have issues however the safest place for your truck is at the 0 setting. When you lift a truck, you need to be prepared to repair it if and when things do fail. Not trying to scare you but you posed the question of what's the safest setting and that is without a doubt the stock setting. The lower the lift, the less likely you are to prematurely wear parts out. The higher you go, the more extreme the angle gets for the CVs and thats when things can start wearing out.
    You do not want to get into changing the setting for every driving and off roading. Changing the setting on the 5100's requires the complete disassembly of the front shock, compressing the spring, moving the bottom plate to the new setting, then putting it all back together again and realigning.
  20. Dec 5, 2011 at 7:01 AM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    RHLM (Red Headlight MOD), Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Toytech 2 inch AAL with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker,
    I just did this with alot of the virginia crew this weekend!
    5100's all the way around, front set at 2.5, get the 2 inch AAL for the rear and the 1/4inch top plate spacer for the drivers side. I am Almost completely level.
    I love this set up!
