Bilstein Lift Question
Discussion in 'Suspension' started by JRod4928, Aug 13, 2012.
  1. Aug 13, 2012 at 4:59 AM
    JRod4928
    JRod4928 [OP] Well-Known Member
    Pittsburgh
    '12 Tacoma SR5
    Extang Trifecta Tonneau WeatherTech Floor Liners Pop & Lock Tailgate Lock Antenna X Black Mesh Grillcraft with Tacoma Badge (Upper) and Cross (Lower) 18" BMF Wheels / Cooper 31.5" Tires 2" Leveling Kit
    Assuming I have a Bilstein adjustable lift with 1.5" AAL in the back, At what lift height setting do I need to install new UCA's? Are they necessary at 2.5" of lift? Can I get 3" out of it?
    Also, is a differential drop recommended assuming this lift?
    If I decided to go with an OME system instead, Would the OME system require UCA's and/or a diff drop as well?
    Bilstein -
    OME -
  2. Aug 13, 2012 at 6:40 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Pass 2" starts getting hard to get it back in spec on your alignment but I seen some people with Bilstein set at 2.5" that didn't need any new UCA but at 3" you will need aftermarket UCA's.
  3. Aug 13, 2012 at 7:49 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    Efffff!
    There's really no getting out of having to get new UCAs if I want a noticable lift, is there?
    What I'm gathering is that you can go to about 2" max, safely, without new UCAs. Is 2" even noticable, and does it provide enough room for 33" tires?
  4. Aug 13, 2012 at 7:52 AM
    sirsaechao
    Tim
    CA
    @3" with 33's you have to trim
  5. Aug 13, 2012 at 7:54 AM
    sirsaechao
    Tim
    CA
    Are you prerunner or 4wd?
  6. Aug 13, 2012 at 7:56 AM
    bridgcat
    bridgcat Well-Known Member
    Alabama
    Mag Grey 4x4 SR5 TRD Offroad
    Avid Off-road Light bar w/ Line-X, American Aluminum Black LP Toolbox, N Fab black step bars,In-Channel Vent Visors, two 10" Rockford subs, Pioneer Double Din DVD player w/ Metra dash kit, 285/65R18 Nitto Trail Grappler MT/s. 18x9" Black XD Monsters. Weathertech digital fit floor mats. Color matched grille with FJ Tacoma badge. De-badged with black, "4x4" badge on tail gate. Mud flap delete mod. Custon TRD decal, color matched rear bumper, Icon extended travel reservoir coilovers, Icon rear reservoir shocks, Dakar rear leaf pack, extended stainless steel brake lines, Camburg uniball upper control arms, timeren bump stops,Beefed Taco carrier bearing drop, Rockford Fosgate Door speakers, Dynomat doors and rear panel, All pro front bumper.
    Anything over 3" you'll need new UCA's for proper alignment. Diff drops (assuming you're a 4x4 obviously) are crap on a second gen tacoma because all it does is actually rotates the diff rather than dropping it. I didn't use one and my cv's look fine.
  7. Aug 13, 2012 at 9:18 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    I'm ok with going to 2.5" without UCAs if it means I can run ~32" tires or so. I have a 4x4 by the way.
    @Bridgcat - your truck looks awesome all blacked out. I was interested in doing this with a TX Pro before I opted to save money and get the SR5 (more practical). How much lift and what equipment did you use on it?
  8. Aug 13, 2012 at 11:11 AM
    bridgcat
    Alabama
    Thanks man. Actually you can run a 32" tire without lifting at all. Mine is actually a TRD Off Road that I threw a set of TX Pro wheels on. The lift I have is listed below.
    1. Icon extended travel reservoir coilovers.
    2. Icon 2.0 rear reservoir shocks.
    3. Camburg uniball UCA's
    4. Dakar rear leaf springs
    5. U-Bolt flip kit
    6. Timbren bump stops
    7. Beef taco carrier bearing drop
    The total lift cost me around $3,200 if I am remembering then about 600 for the install of everything. There are plenty of great lift options out there like toytec and OME but I decided to go with Icon because I wanted a performance suspension that I could hammer on a little harder if I need to. Check out my build for more information.
  9. Aug 13, 2012 at 11:33 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    Nice - I like the TRD wheels too, and was going to black-out my truck, but I think I'm going to go another route once I begin my mods (just brought the truck home Friday). It's MGM as well (looks like yours is).
    I don't really need a performance suspension myself - i'll rarely go off-road with it. I just would like a small lift to put larger tires under it. The BIGGEST things for me are: 1) to maintain ride quality 2) do not damage anything (ball joints, cv joints, etc.) and maintain alignment 3) Price (I plan on installing myself) - preferably no more than 800 dollars (incl. alignment)
    The problem is that I have a Toyota Warranty for 100,000 miles that I don't want to void because I installed a lift that was too drastic so I'm trying to obtain a 2-2.5" lift without over-stressing other parts of the truck that Toyota may claim was caused by a lift. Has anyone experienced anything like this when lifting their truck?
  10. Aug 14, 2012 at 3:05 PM
    2010TRD
    2010TRD Well-Known Member
    Thomas
    Waldo, FL
    2010 MGM trd offroad DCSB
    Billistein 5100 front/rears, Toytec 2" AAL Custom grill, All Pro rear bumper, All Pro sliders, Anytime elocker/foglights, Rear diff vent relocated, W/O seat covers, weathertech mats/visors, nfab tire racK, cobra 75 stealth CB, Custom engine/trans skids 3/8", Hella and HID behind grill, LED bar backup light, LED pods under cab (rocklights)
    I have a 3" lift on my 4x4
    It's a spacer upfront (Im broke right now so went cheap route)
    2.5 AAL in rear with billies
    No diff drop ....and alignment turned out good
    All is good after 4K miles
    Front is stiff.... Due to preload spacers......hope to afford billies upfront soon
    Rear feels great, on and off road
    No uca were needed for my 3" lift
    Had a Toyota tech, look at my truck....and he says it all looks good to him....shouldn't have any excess stress or wear on components
