Bilstein question from a newbie
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brwndg, Mar 4, 2014.
  1. Mar 4, 2014 at 5:59 PM
    brwndg
    brwndg [OP] Active Member
    Tim
    Reston, VA
    2006 DCLB 4x4 TRD Sport
    I have been reading till my eyes are bleeding about putting 5100's all around my 2006 TRD Sport.
    Want to leave it stock so I guess leaving the fronts at 0.0" would be the best to keep it level.
  2. Mar 4, 2014 at 6:04 PM
    talofox
    talofox Northwest Member
    Justin
    Port Angeles, WA/Minot,ND
    '07 DCSB 6spd
    So whats the question?
  3. Mar 4, 2014 at 6:31 PM
    YotaOwner
    YotaOwner Well-Known Member
    Zack
    Western North Carolina
    2000 Tacoma Reg Cab
    X2
  4. Mar 4, 2014 at 6:32 PM
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    X3
  5. Mar 4, 2014 at 7:02 PM
    hakabo
    hakabo Well-Known Member
    Jacob
    Concord, NC
    08 urban runner 4x4
    I think yes is the answer...
  6. Mar 4, 2014 at 7:18 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Are you wanting to just add new shocks and wondering if the 5100's are a good shock? Your not interested in lifting at all, correct?
  7. Mar 4, 2014 at 7:30 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I think more "level" would be the next setting up. .85" I think
  8. Mar 4, 2014 at 7:50 PM
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    why not just stick with stock if you are gonna leave the 5100s at the 0 setting :notsure:
  9. Mar 4, 2014 at 7:52 PM
    YotaOwner
    Zack
    2000 Tacoma Reg Cab
    Maybe he needs new shocks?
  10. Mar 5, 2014 at 6:09 AM
    brwndg
    Tim
    Reston, VA
    Sorry, didn't realize I was being that vague.
    Yes, the stock Bilstein HD are rusted out & shot, so will be replacing w Bilstein 5100s on front & rear.
    I had planned on replacing w 4600s but seems practically everybody on here says that it is worth the extra $$ for the 5100s.
    Truck is an '06 DCLB TRD Sport, and I want to keep truck level & not interested in lifts.
    Not planning on doing any hard-core off roading, mostly highway, but will be traveling fire roads, power lines, farm fields, etc. while in pursuit of deer, turkey, bass, & trout.
    So what should the front shocks be set at? 0.85 or 0.0?
    Thanks for responses so far
  11. Mar 5, 2014 at 6:15 AM
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    .85 will level you out. I just put mine in and put them all the way up. I sit a little nose high but not too much.
    Are you doing it yourself?
  12. Mar 5, 2014 at 6:16 AM
    ajw1986
    ajw1986 Well-Known Member
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    Get your truck on a flat surface, measure ground to bottom of fender on the front and back, see the difference and adjust accordingly. Also remember, you will want to get the 1/4" spacer for the driver side lean
  13. Mar 5, 2014 at 6:51 AM
    brwndg
    Tim
    Reston, VA
    I am planning on doing it myself. No coil overs on the front so it should be a relatively simple job if I can get the rusted nut off.
    Yes, i was planning on doing a measurement prior to the install & after. What is this 1/4" spacer that you mentioned?
  14. Mar 5, 2014 at 7:51 AM
    ajw1986
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
  15. Mar 5, 2014 at 8:09 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    If he's keeping the stock springs I don't think he has to worry about the spacer
  16. Mar 5, 2014 at 8:13 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    If your looking to keep the factory stance , than the 0 setting on the 5100's. If you're looking to level the truck, than it will be either .85 or 1.75. Depends how sagged the rear springs are. 1.75" on mine leveled the truck.
  17. Mar 5, 2014 at 8:28 AM
    speedydave
    speedydave Well-Known Member
    Dave
    Hickory, Nc
    Mustang GT
    If you are going to do it, you might as well set them at .85.
    If you just need new shocks, and don't care about the lift, you could probably get a full set of the OEM Bilsteins for next to nothing with low miles. I have a set in my garage with 1500 miles on them. I'm sure there are lots of them around.
  18. Mar 23, 2014 at 6:35 AM
    Redsoxnation
    Redsoxnation Well-Known Member
    Pa.
    PreRunner TRD 4X4 Impulse Red
    none yet...
    in the same situation ...2006 TRD extended cab 4x4 ...65k really no signs of sloppy drive or tread cupping. I was looking at Monroe quick strut assy. 171371's for the front.. I know cheap alternative . I don't need Baja strength shocks.. I can't do this myself.. no suspension tools what so ever.. :( Blisteins really that much better ?
  19. Mar 23, 2014 at 6:54 AM
    moondeath
    Pa, Gardners
    Those are pretty much the same price as 5100's. Why not get the better shock that has a lifetime warranty and is hands down a better shock than Monroe.
  20. Mar 23, 2014 at 9:55 PM
    Sbasser
    Sbasser Active Member
    Renton Washington
    TRD Off Road 4x4
    Trailer pkg. 6 spd.
    I've still got the original shocks on my '06 Tacoma 4x4, but replaced the stock shocks on my '97 GMC 4x4 with Bilsteins and loved them. Installed them myself. I put KYB's on my 2wd '68 GMC, and they were good, but not wonderful. You don't need "suspension tools", just some wrenches and a 1/2" drive socket set. I couldn't tell you if you need metric wrenches and sockets or SAE, because nothing has broken in 93k. I have both on hand, if it happens. If/when these shocks go bad, I'll put more of the same on.
