Bilstein rear shock selection help.
Discussion in '1st Gen. Tacomas (1995-2004)' started by scyot89, Sep 27, 2011.
  1. Sep 27, 2011 at 6:35 PM
    scyot89
    scyot89 [OP] Active Member
    TJ
    South Carolina
    2002 Tacoma 3.4L 4X4 5spd
    Stock
    I need help on choosing the correct rear shocks. I do not have a lift on my truck and I do not plan to put one on it. should I go with the HD's, 5100's, or 5125's ? downsouthmotorsports has on they're website that the 5125's are for a stock truck with no rear lift. They also say the 5100's in the rear are for a truck thats lifted in the rear. Now ive read on a post on here from different ppl that the 5125's are longer than stock and require an adaptor to work on a stock truck. who is correct here ? again I want to leave my rear height stock. Im just looking for a shock thats going to be a little bit beefier than stock but have a great ride. I sure would appreciate someone who knows what the best choice is, and actually knows what they are talking about. Thanks.
  2. Sep 27, 2011 at 10:06 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The 5100s are too long for a no lift application.
    The 5125's come in varying sizes, including ones that are short enough for a no lift application. Call DSM, they can help you with calculating the correct length for your application.
    The 5125 will be more expensive that the HDs but are probably a better shock.
    The adapters you've read about are for 2nd gens. 2nd gens have a different top mount. 1st gens do not require an adapter to run any of these 3 models.
  3. Sep 28, 2011 at 12:29 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You sure mike? i thought it was 5100s are good for only up to 3'' of lift and stock heights. After 3'' you NEED to get 5125s or 5150s as they come in longer lengths..
  4. Sep 28, 2011 at 12:40 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  5. Sep 28, 2011 at 12:52 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh yea. Damn i even remember reading that lol
    OP check the 2nd link. not that first
  6. Sep 28, 2011 at 12:56 AM
    Norton
    Thanks for catching bad link. Not sure what happened, since I tested both before posting. :confused: BOTH are now good (again).
  7. Sep 28, 2011 at 7:50 PM
    Digiratus
    Roaming the PNW
    The RedHead
    +1 for you sir. Good links.
    Monte, you are correct as far as you go. The RCD spec'd 5100s will handle up to 3" of lift. However, for the OPs circumstances, with no lift or even a slight negative lift due to original springs, the collapsed length of the shock becomes critical.
    A shock will wear out quickly if it is the limiting factor for up travel, which is what happens when the shock is too long.
  8. Sep 29, 2011 at 8:05 AM
    scyot89
    TJ
    South Carolina
    Stock
    Thanks for the info. Mike, so i need to call DSM and get the 5100/5125 combo and ask to get the 5125's in stock length right ? Ive already ordered the one inch spacer for the front, so probably setting the 5100 in the front to .85" plus the spacer would be about right for leveling my truck im guessing, if not just a little under level correct ? I appreciate yall helpin me out, everybody i talk to around here even at the 4x4 centers do not seem to know there a$$ from a hole in the ground. I know im asking a lot of questions so if yall got any kind of electrical or audio questions ask me lol.
  9. Sep 29, 2011 at 10:02 AM
    asus611
    asus611 Well-Known Member
    CA
    03 Double Cab Prerunner
    Don't know if this helps, but I have a 2003 Prerunner double cab. I bought my shocks/struts from DSM (Sonny), and got 5100 for the front, and 5125 for the back. Rear is totally stock, probably saggy a little due to the age. No plans to lift rear.
    I put my front 5100's at the middle setting, no spacers or anything just set in the middle and my truck is just about level front to back now. When I first installed the 5100's I was actually a liiiitle nose high, but now I'm just about even.
    I would imagine if you do spacers and the middle, your front end will be really, really nose high. Pics of my truck are in the "5100" install thread somewhere further down in this forum.
  10. Sep 29, 2011 at 10:13 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ugh..spacers..
    if you use the spacer, which i don't recomend, and the 5100 set a the middle setting, i think thats 1.5'' on 1st gens, then you will be a 2.5 up front so you wil be really nose high. Might as well just set the 5100s at 2.5'' and never use the spacer. You'd need an AAL tho to come close to leveling at that point.
  11. Sep 29, 2011 at 8:56 PM
    Digiratus
    Roaming the PNW
    The RedHead
    What is the 1" spacer? Is it a spacer kit, one for each side? Keep in mind, if the spacer is 1" thick it will actually lift the truck about 2". If it is 1/2" thick, the supplier might refer to it as a 1" lift spacer. In either case, you really don't need it.
    As others have said, if you go the route of 5100s for the front, set the 5100s spring perch on the middle setting. This will give you about 1.25-1.5" of lift and pretty much level the front with the back.
  12. Sep 29, 2011 at 9:01 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    No, sorry... I instaled 5100's on my 2005 DC Tacoma with no lift... They are an excellent upgrade shock from the yellow Bilsteins and not expensive. I noticed a better ride and handling, and this was before I installed the Ride Rite air bags (to stop the bottoming-out/ harsh ride).
  13. Sep 29, 2011 at 9:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    lol you didn't read this whole thing, did you haha
  14. Sep 29, 2011 at 10:08 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I am trying to figure out what that has to do with the OPs 1st gen. I don't even think it is the shock between generations, let alone the compressed and extended lengths.
  15. Sep 30, 2011 at 8:20 AM
    David K
    Sorry if I missed something... I read someone say a 5100 is too long for a no lift application... and that isn't the case... a 5100 is a direct replacement, heavier duty shock than the stock Bilsteins and no lift is required to fit.
    If I mis-read, I am sorry. Carry on!
  16. Sep 30, 2011 at 8:28 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    5100s are too long for no lift especially if you have saggy leafs. so you should use 5125s as you can get them shorter for stock replacements.
    Check out the two link posted earlier.
  17. Sep 30, 2011 at 8:56 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Folks, they are talking first gen trucks and part numbers here!
    We second gen guys best keep moving along. Nothing to see here! :D
  18. Sep 30, 2011 at 8:59 AM
    2011TACOMAWHR
    2011TACOMAWHR TACOMA 2011
    aaron
    lancaster SC
    2011 OR dbcb shortie
    big tires and tiny rims
    I love my 5150s w
  19. Sep 30, 2011 at 9:47 AM
    David K
    OK... well, I put 5100s on my non-lifted/ saggy spring 2005 Taco. They were great. I also owned a 2001 Taco... and they both look pretty much the same under the back side. However, check with Bilstein for the correct application model for your 1st gen Taco!
  20. Sep 30, 2011 at 10:56 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    exactly
