Bilstein replacement?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoMAss, Aug 10, 2021.
  1. Aug 10, 2021 at 7:35 AM
    TacoMAss
    TacoMAss [OP] Member
    2016 TRD OFFRD
    non yet :(
    Howdy
    looks like my rear Bilstein shocks are worn out, my mechanic was hanging from the truck on the lift and he said I am 250lbs and I should not be able to rock the shocks as much as I do :)
    I know there are a lot of things to consider when choosing shocks/leaf springs/combos etc
    but what is the consensus on ride quality with not a ton of weight vs ride quality and not bottoming out when fully loaded? :bikewhoops:
    Replace with OEM Bilstein? Fox? Rough Country?
    Thanks!!
  2. Aug 10, 2021 at 7:41 AM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    I replaced my OR rear shocks with Bilstein 5100’s . I cant tell much difference in ride quality good or bad.
    What I can say is my Timbren SES progressive bump stops in the rear absolutely help with rear sag when loaded or towing. With the bed unloaded, Timbrens have zero influence, and its a stock ride.
