Bilstein settings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nitrus5, Feb 16, 2009.
Bilstein 5100 Setting
  1. 0
    38 vote(s)
    6.6%
  2. 1.75
    294 vote(s)
    51.3%
  3. 2.5
    241 vote(s)
    42.1%
  1. Sep 7, 2010 at 11:55 PM
    #121
    renmauzo
    renmauzo Member
    Arizona.
    '10 DC LB in Timberland Mica.
    Got the TSB done on a Double Cab Long Bed 4x4 Sport, and the rake is now ridiculous. I'm going to get the 5100's, but I'm having trouble deciding how to set them.
    Does anyone have any input on how to set them assuming that I often tow stuff/carry stuff in the bed? I was thinking .85 ... but then I consider the weight in the bed and how that would affect the rake and I'm just not sure.
    I don't want to be riding around with a permanent wheelie going on, but I also don't want to ride around like a toy chihuahua carrying a 20lb bone anymore, either.
  2. Sep 8, 2010 at 4:22 AM
    #122
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Why would you remove a leaf on the dakars?:confused:
    Just go with a 1.5" aal.... that's the same lift as the tsb for $80
  3. Sep 8, 2010 at 11:11 AM
    #123
    tony92629
    tony92629 Well-Known Member
    Tony
    Dana Point
    2010 White Tacoma Prerunner
    5100's all the way around. Front set at .85. Camburg Spindles. Camburg Uniball 1.25 UCA's. Total Chaos LCA skid plates. Custom Deaver 10 pack rear leaf spring. BFG AT KO's 285/70/17, Weathertech floor liners, Wet Okoles. Midland CB/PA, Firestick.
    5100's set at 2.5 with TSB and a 1" block on the rear - Looking for AT's 265/70/17's
  4. Sep 9, 2010 at 11:09 AM
    #124
    RedskinRedTaco
    RedskinRedTaco Well-Known Member
    Paul
    Virginia Beach, VA
    07 TRD 4x4 Offroad Crewcab
    Trifecta folding Touneau Cover, 275/70/16 LTX M/S, Running Boards, Dynamat, tint, Alpine W404 Video system w/ backup cam, Sirius Sat, Polk Audio Component Speakers frt and back, Alpine 4x50 amp. Billy's 5100's set @ 1 3/4, 1" rear blocks, Rear TSB, trimmed frt mud flaps 4", TRD Exhuast, K&N filter. Electric Brake.
    I had friends at the local Toyota dealer do mine. I asked them to set them at 2.5 and install my 1" blocks. They ended up setting them at 1.75 to keep all the drive angles in correct specs. I am totally happy with them. !st I had 265/65/16 BFG A/T's now i'm I am running LTX M/S's 275/70/16's. Heres both pictures.
  5. Sep 10, 2010 at 6:42 AM
    #125
    tony92629
    Tony
    Dana Point
    Nice truck - Are those Avid sliders? I am looking into getting a pair.
  6. Sep 10, 2010 at 6:44 AM
    #126
    RedskinRedTaco
    Paul
    Virginia Beach, VA
    Thanks! Love My Taco. They are OEM running boards I scored on Craigslist.
  7. Sep 28, 2010 at 7:43 PM
    #127
    huntark03
    huntark03 I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
    Do you mean AAL in the rear?
  8. Sep 28, 2010 at 7:50 PM
    #128
    huntark03
    Maumelle, AR
    Now that's inspiration!!! I think I am going with a similar setup...Eibach coils/5100's set at .85 and rear spring TSB with Toytec 1.5 AAL!!! I hope I get a similar look!!!
  9. Oct 4, 2010 at 4:08 PM
    #129
    Steig
    Steig Well-Known Member
    Tacoma TRD off road
    What is involved to change the settings on the Bilsteins ? How hard is it to do this ? Does truck have to re-aligned after the change ?
  10. Oct 5, 2010 at 7:51 PM
    #130
    dirtytaco2010
    dirtytaco2010 Well-Known Member
    south lake tahoe, CA baby
    SR5 TRD Sport LB
    custom badging, Black Badges, tint, General AT/2's, nerf bars black, ultra-gauge,toytec AAL, removed mud flaps, Bilstein 5100's @ 2.75, AFE pro dry s air fliter, spidertrax, black rock 17'' wheels
    i did AAL and 2.5 no alignment issues
  11. Jan 11, 2011 at 11:28 PM
    #131
    jfisher
    jfisher Active Member
    5100's @ 1.75" and TSB rear
  12. Jan 12, 2011 at 6:14 AM
    #132
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    To change the settings you have to remove the coil strut assembly, compress the spring and remove it from the strut, move the clip up to the setting you want and then reassemble everything. Sounds like a lot of work but I've done it about 4 times now and can do it in 50 minutes. An alignment will be needed after the change.
  13. Jan 12, 2011 at 6:25 AM
    #133
    Bama_TACO
    Winfield, AL
    After running the 5100s for a few months at .85" with the stock 3 leaf springs, this weekend I installed - rear Icon progressive 1.5" 3 leaf AAL and moved the front 5100s up the 2.5" setting. The AAL was supposed to be 1.5" but after I got it in I was sitting about 2 1/4" higher than stock. I decided to move the fronts to 1.75" for a slight rake. It was too much rake so then I moved the fronts up to 2.5". I have 1 1/4" of rake now. Measurements are 37" in the front, 38 1/4" in the rear with 265/65/17 Michelin LTX-AT2s. I love the look and the ride is nowhere near as firm as I was afraid it was going to be. Now I've got to get it aligned, hopefully tomorrow.
    (in this picture it may look nose high but I think it's the angle of the picture)
    This is what it looked like when I bought it.
  14. Jan 15, 2011 at 9:58 AM
    #134
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    When I get my arrival of packages from DSM and ToyTec, I am going with 1.75" setting and 1.5" AAL. Stock wheels and tires.
  15. Jan 15, 2011 at 6:22 PM
    #135
    vermintrex
    vermintrex Well-Known Member
    Vancouver
    TRD SPORT Shorty
    BFG A/T KO 265/70/17, '11 FJ wheels, 5100's all four corners, Eibach springs, 1/4" Taco lean spacer, Leer 100XR, WeatherTech liners, trimmed mud flaps and I farted in it.
    Have 5100's on the way, along with the Toytec/Eibach 1.6" coils and the .25" Taco lean spacer. Truck came with the TSB leaf pack so I'm hoping I get near level with the 5100's set to 0 and 1.6" lift up front. If I still have a tiny bit of rake that's ok, I don't want it going nose high once I load the bed or tow.
  16. Mar 6, 2011 at 7:01 PM
    #136
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    So my 265/75/16 Duratrac's haven't seemed to make my MPG worse. I've been wanting to go to 5100's set at 1.75", but with gas prices spiking I'm afraid the additional frontal area with the lift will hurt my MPG by 1-2. What's been everyone's experience with the 5100 lift? Will it hurt the MPG much?
  17. Mar 21, 2011 at 6:05 AM
    #137
    Bama_TACO
    Winfield, AL
    I lifted first with stock size tires and didn't notice that much of a change in MPG at all. Then I put on the 285/65/18 Load range E tires and I've dropped about 1.5 MPG.
  18. Mar 31, 2011 at 1:23 PM
    #138
    WhoreHey
    WhoreHey Active Member
    Jorge
    Yorba Linda
    06 DC SB PreRunner TRD Off Road
    just getting started : (
    sub'd, since this is at the top of the list for my truck :D
  19. Apr 1, 2011 at 2:31 PM
    #139
    robszuki
    robszuki Member
    British Columbia Canada
    Tacoma sr5 Trd Sport
    Leveler kit, tires and rims, full window tint, audio system
    Mine had a 2" leveling kit when I got it.
    Did an AAL and added 32.5 Nitto Muds.
    Sits slightly higher in the rear but leaf pack should settle some over summer as I haul dirt bike or quad or w.h.y.
    Had 4 wheel alignment done and was no issues.
    Tracks straight and drives like a truck should.
    Guess I will replace fronts with coilovers at some point.
    First pic was the day I got it.
    Second two with the new boots.
    As seen it was squatting in the rear until after the spring refresh.
  20. Apr 1, 2011 at 2:48 PM
    #140
    robszuki
    robszuki Member
    With the AAL.
