bilstein shock difference???
Discussion in 'Suspension' started by tacomaman06, Apr 5, 2008.
  1. Apr 5, 2008 at 4:37 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  2. Apr 5, 2008 at 5:27 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
  3. Apr 5, 2008 at 6:03 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Thats who i went through sonny is awesome well worth the money.
  4. Apr 5, 2008 at 6:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i had thought about it, but im not going to lift or anything, and im not needing shocks yet.....im at 30k right now,but i'll probably just get regular billy's when its time...........i was just wondering the difference.
  5. Apr 11, 2008 at 10:39 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    I believe that even the Toyota issued TRD Bilstein's are still a fleet type shock. The yellow Bilstein HD's that I replaced, at 30,000 as one on the rear had blown, on my '99 TRD were almost twice the diameter of the original ones. The same with the 5100's that I just put on this '08 TRD truck. The 5100's and the yellow HD replacements are a 46mm piston? and alot better dampening than the original issue Bilstein's. I agree about the 5100's, you can adjust if needed, from Downsouth Motorsports. Offer $258 on best offer and I'll bet you a beer they take it. :cool:
    http://cgi.ebay.com/ebaymotors/05-0...018QQitemZ280217394530QQrdZ1QQsspagenameZWDVW
  6. Apr 12, 2008 at 9:07 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    how much of a difference could you tell between the stock billy's and the hd billys?? and yeah, they do look a a good bit bigger.
  7. Apr 12, 2008 at 10:49 AM
    4x4x4trd
    North Texas
    A good friend and I both replaced the factory Bilstein HD's with the replacement yellow HD's from Performance Products at the same time. We also replaced the tires at this time with Michelin LTX M/S. This was on '98 and '99 TRD trucks. We were both really impressed at the difference in ride and handling, but to be honest it may have been the combination of the two. I do think mine took the bumps a lot smoother with the new shocks but hey the old ones had 30,000 on them.
    Kinda like someone driving your truck and saying its pulling right a little. You drive it every day and don't notice it changing day by day. I do feel the 5100's are as good or better than the new replacement HD's and the ability to adjust the lift to level, ect. is just a plus. I'm very happy with the 5100's and there is a big difference over the stock issue HD's. I only went to the .85" setting so my ride isn't as firm as some that have gone for more lift. When it comes time to replace tires I'll have to go with the Michelin's again. I'm 90% on pavement and not real radical when I do get off road and they fill my needs.
  8. Apr 12, 2008 at 11:16 AM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    The bilstein 5100's are only adjustable in the front, correct? To raise the rear either new leaf packs or blocks need to be used? I want to lift my truck not too much, about 2". I want to keep the rake in the truck so I have to lift the back as much as the front, I'm assuming. I don't want to get into dropping the diff or replacing brake lines. Are the 5100's plus a block or leaf packs the most economical way?
  9. Apr 12, 2008 at 11:26 AM
    4x4x4trd
    North Texas
    The 5100's are adjustable in the front only and I believe only for non lifted or not more than 2" over stock? I'm sure others can help you out on the blocks as I left mine stock height.
  10. Apr 13, 2008 at 7:55 PM
    Evil Monkey
    Robert
    Escondido, CA
    That's correct. The rears are not adjustable. I have the 5100s front and back with the front set at 2.5 and the TSB leaf springs on the back with no blocks. The truck wells are the same height front and rear over the tires. If you had the TSB in the back (which lifts the back over stock) you could set the front to .85 or 1.75 and have a slight downward rake. If you don't have or want the TSB springs, you could lift the back. Measure from the top of your wheel straight up to the wheel well. My TSB springs lift the rear to 7.5" above the wheel.
  11. Apr 13, 2008 at 10:32 PM
    yak
    yak member
    so cal
    08 indigo dc prerunner sr5
    roll n lock bed cover - tinted window - debadge - blue interior light
    If I dont have TSB done, how high can i lift the front using this 5100?
    EDIT: Do you even need TSB on 08?
  12. Apr 14, 2008 at 6:07 AM
    4x4x4trd
    North Texas
    The 5100's are adjustable to 4 heights, stock, .85", 1.75", and 2.5".
    Your call on having the TSB done. If you only have 3 leafs total in the rear you don't have it, meaning Toyota is still sending out new trucks that way. The 08's aren't officially listed on the TSB as you can tell reading on here.
  13. Apr 22, 2008 at 9:37 PM
    2_wheels
    2_wheels Well-Known Member
    Coeur d'Alene, ID
    06 Tacoma TRD Sport 4x4 dbl cab
    So, is the TSB basically an add a leaf? how many leafs are there? After reading this forum for a couple days, I'm thinking the 5100's 2.5" and after market add a leafs.
    Do you or anyone on this forum feel that the 5100's are really stiff set at the 2.5" mark? would I be better off going with a spacer and add a leaf?
    greatly appreciated!
  14. Apr 22, 2008 at 9:46 PM
    4x4x4trd
    North Texas
    Several have said they get quite stiff set at the full 2.5" setting.
    I only went at .85" and love the ride after having both done. Only slightly more firm than the fleet type shocks that came on my TRD truck at that setting.
  15. May 26, 2008 at 11:22 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    i've got a 3" lift in the front. when i put the bilsteins on will i need to keep them at stock setting?
  16. May 26, 2008 at 4:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes. :)
  17. Apr 21, 2009 at 1:12 AM
    thekidcatcher
    thekidcatcher Well-Known Member
    Corpus Christi, TX
    05 TRD offroad SR5
    Legs- --Helo rims --KM3 285/75/R16 --Bilstein 5100 in front with OME 886 --Dakar with extra leaf --Total Chaos UCA's --5165's Bilstein in the rear Electronics- --Warn M8000 w/ Warn wirless remote --Cobra 29LTD CB, --12in sub with alpine amp , --Dual Battery, --Warn Air compressor --URD MAF sensor, --touchscreen cd player hooked up to front and rear cameras Armor- --All-Pro offroad front/rear/rocksliders --AP skid plate, diff armor Cajones- --JBA headers, midpipe, exhaust --Safari Snorkel --4.56s ECGS Misc- highlift jack --UWS toolbox --u bolt flip kit --Tepui Kukenam Custom- --in dash inverter --on-board shower system --dvd anytime mod --custom bed rack and tiregate.
    Out of curiosity, I have the Toytec 3inch lift, I want the 5100 adjustable shocks for sure. What happens if you do put them above the stock setting? I am thinkin of getting the Total Chaos UCA and wonderin if by adjusting a little higher I could get rid of some rubbage.
  18. Apr 21, 2009 at 6:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Do you have the OME spring?
  19. Apr 21, 2009 at 3:20 PM
    thekidcatcher
    Corpus Christi, TX
    05 TRD offroad SR5
    I got the one that came with the lift, I went ahead and bought it too. :)
