Bilstein Shock question?
Discussion in '1st Gen. Tacomas (1995-2004)' started by staplak, Dec 12, 2009.
  1. Dec 12, 2009 at 7:14 AM
    staplak
    staplak [OP] Well-Known Member
    Guntersville, AL
    04 Black Prerunner SR5 DoubleCab
    Thule Xsporter Rack
    This question may be retarted but i have seen many pictures of the rear bilstein shocks put on different ways.(meaning dust boot on top and some on bottom) I just installed mine on my truck and put them on with the boot on the bottom half. Could someone clear this up for me on the proper way to install them.
  2. Dec 12, 2009 at 7:21 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    IMO, boot on bottom is asking for shit to collect in it bringing about it's early demise. How could it work any better upside down? Seems pointless.
  3. Dec 12, 2009 at 7:33 AM
    quattrokiwi
    quattrokiwi Well-Known Member
    Bruce
    Nor Cal
    04 Tacoma, Limited, TRD, Locked, Geared, 4x4
    put the boot up for the same reason, didn't want to get a torn boot from a stick or something
  4. Dec 12, 2009 at 7:33 AM
    smuook
    smuook Daily Driver "Plus"
    Frank
    Loganville, GA
    2004 DC V6 PreRunner
    Billy 5100, Satoshi, MBW Wheels, All Pro Front Bumper with 3x PIAA 530, LED dash lighting, other stuff too much to list
    From Bilstein:
    [FONT=Arial, Helvetica, sans-serif]Do I mount the shocks with the boot pointing up or down?[/FONT] [FONT=Arial, Helvetica, sans-serif]With the internal design of the Bilstein monotube gas shocks, it does not matter whether the shocks are mounted with the shock rod side up or down. There are some minor advantages in longetivity and overall suspension effectiveness with the shock rod pointed down, and there are many instances where Bilstein has changed the orientation to take advantage of these minor improvements where there are no clearance problems. If there is an option, we recommend mounting the shock with the shock rod and boot pointing down, but in the grand scheme of things, there is no noticeable difference.[/FONT]
    http://www.bilsteinshocks.com/bilstein/html/faq.html#10
  5. Dec 12, 2009 at 7:35 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    boot goes to the bottom on the rears. to me.....it doesnt really matter which way you mount them tho.........i had mine turned with boot up for about 6k miles........then flipped them over...couldnt tell a difference either way. one thing i did notice with the boot on top.....they collected water like crazy.
  6. Dec 12, 2009 at 7:38 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Hmmm? Seems like fluid leak would occur sooner with crap collecting in the boot being upside down & having more grit wearing on the seal. And as was stated, bigger possibility of something off road gouging or tearing the boot. Guess it doesn't matter that much either way according to Bilstein.
  7. Dec 12, 2009 at 7:41 AM
    staplak
    Guntersville, AL
    Thule Xsporter Rack
    Thanks for the replies. I was kinda of worried there for a minute.
  8. Dec 12, 2009 at 7:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    More importantly, they are valved differently for rebound, and compression. By inverting them, of running them a different orientation from which they were designed, it will/could give a wierd ride quality. Most times, rebound is going to be slower than compression. I belive the 5100's have a rebound dapening of 255 Nm/sec. and a compression dampening of 125 Nm/sec. I cant remember exactly....
  9. Nov 11, 2011 at 5:21 PM
    mytoyo2
    mytoyo2 Mytoyo2
    Frank
    va
    08tacoma4x4 5spd 4cyl
    afe cold air intake,tornado fuel miser,body armor front bumper,dual magna flow exhaust,blacked out factory rims and fender flares,baja lights,cooper ATR tires,Gforce,hood scoop,peel n seal bed cover,chrome nerf bars
    I just got the 5100s for my 08 and they only mount 1 way and thats with the boot to the top
  10. Nov 11, 2011 at 5:32 PM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Dirty Terc
    Scratches, dents, and junkyard parts.
    Holy Thread Revival!! :p
    That's because you're a 2nd gen. This discussion was in regards to the rear bilstien shocks on 1st gens which can be mounted either way.;)
  11. Nov 11, 2011 at 5:37 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    how or why idk but supposedly its unsprung weight putting it with the boot down. At least thats what ive been told
