Bilstein shocks and 0881 coil springsl
Discussion in '1st Gen. Tacomas (1995-2004)' started by Danno 1948, May 17, 2016.
  1. May 17, 2016 at 1:30 PM
    Danno 1948
    Danno 1948 [OP] Danno 1948
    Dan
    Ocala,Fl.
    2023 Tacoma Trail Edition/ Ice White
    little bit of everything
    Im putting bilsteins 5100 shocks and 881 coil springs on the front of my 02 Toyota to get it leveled out, what setting should I set the 5100 at, I have 2" lift in the rear with 5100 and extra leaf. Its a 3.4 eng with automatic trans.... Thanks
  2. May 18, 2016 at 11:15 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Lowest setting with the 881's. From what I understand, those springs are not meant to be preloaded
  3. May 18, 2016 at 2:16 PM
    Danno 1948
    Dan
    Ocala,Fl.
    so that will give me the 2" of lift I need to match the rear I hope....
  4. May 18, 2016 at 2:24 PM
    boostedka
    James
    NM
    On a V6 It should. You can always add too plate spacers for and extra 1/4" if necessary.
  5. May 18, 2016 at 2:54 PM
    Danno 1948
    Dan
    Ocala,Fl.
    thanks very much
  6. May 18, 2016 at 5:47 PM
    exminnesotaboy
    exminnesotaboy Well-Known Member
    Maple Grove, MN
    01 Tacoma 4x4 V6 SR5 TRD Xtra Cab
    Bilstein 5100's / OME 881's / Wheelers 5 leaf pack / Level8 MK6/ 265/75-16 Bridgestone Dueler tires
  7. May 18, 2016 at 8:30 PM
    Danno 1948
    Dan
    Ocala,Fl.
  8. May 22, 2016 at 9:46 PM
    ashleyroachclip
    ashleyroachclip Well-Known Member
    Where are you buying your 881 and bilstiens , and do the sell a loaded strut , looking to level a stock 3.4 manual trans extra cab 95.5 .
    Thank you
