Bilstein shocks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hoff, Jun 19, 2017.
  1. Jun 19, 2017 at 7:30 AM
    Hoff
    Hoff [OP] Well-Known Member
    Tacoma
    kjp4575 likes this.
  2. Jun 19, 2017 at 7:36 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Powerprozeus and Hoff[OP] like this.
  3. Jun 19, 2017 at 7:39 AM
    bilplat
    bilplat Simply Driving Into Mordor
    Bill
    Denver, CO
    '17 White A/T 4x4 TRD OR DCSB
    ARE Hard Top
    Which bilsteins? The ones from the Off Road? If so, you'll get a softer feeling ride, at high speeds on streets and low speeds on speed bumps and offroad, at least relative to the hitachis you've got on now.
    Better options? Depends on how much you want to spend. I've heard good things about the 5100s and even better things about the 6112/5160 setup. You can set these to factory ride height and just reap the benefits of better valving and thicker bodies. Keep in mind the 6112/5160s are digressive shocks, as opposed to the more common progressive shocks, which means they'll be smoother at higher speeds than progressive, but harder at slower speeds.
    Powerprozeus likes this.
  4. Jun 19, 2017 at 7:41 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    For future reference, the 4600s and the 5100s are the same shock internally. There would be no benefit to running 5100s set at 0 vs just running the 4600s.
    http://www.shockwarehouse.com/news/bilstein-5100-vs-bilstein-heavy-duty.cfm
    Deucer01, hiPSI and bilplat[QUOTED] like this.
  5. Jun 19, 2017 at 7:41 AM
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    I noticed a pretty drastic improvement in how my truck rode when I swapped to the 6112 front and 5100 rear suspension. I only set mine to one notch up in front to get the truck level. Worth the money in my experience.
    As you can see, it still looks pretty stock.
  6. Jun 19, 2017 at 7:42 AM
    AJ88
    AJ88 Well-Known Member
    AJ
    KY
    ‘15 TRD OFF ROAD DCSB
    I have 3rd gen 5100s all around. Front at the first notch (0.65"). Gave me an almost level ride, slight front rake. I think the ride is better with the 5100s, seems smoother. If you don't want any lift I would still suggest the 5100s and just leave them at the default setting.
    kjp4575 likes this.
  7. Jun 19, 2017 at 7:50 AM
    bilplat
    Bill
    Denver, CO
    ARE Hard Top
    EatSleepTacos[QUOTED] likes this.
  8. Jun 19, 2017 at 8:03 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    I just replaced the stock hitachis with TRD OR Bilstein takeoffs and 'stiff ride' leafs this past weekend. Ride quality is very much the same, however the damping characteristics and how the truck handles consecutive bumps has significantly improved.
    Edit: My hitachis are the SR5/Limited variety. Yours, on the Sport model, are much stiffer.
    GotToyota likes this.
  9. Jun 19, 2017 at 8:08 AM
    Silentshredr
    Silentshredr Well-Known Member
    Chuck
    16 DclbOr4x4
    I've run the factory bilsteins on my Trdor, 5100 at zero, 0.65, and 1.1. Factory shocks to 5100 at lowest setting is two different rides. No way they are valved the same. I'd recommend running at no higher than 2nd notch. Biggest difference between the two that I noticed is the decrease in nose dive and body roll with the 5100. Definite improvement for me.
    Hoff[OP] likes this.
  10. Jun 19, 2017 at 8:12 AM
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    If you go with the stock OR shocks I would also get the coils too. My TRD 4x4 DCSB OR ride was as comfortable a ride as I've driven. I have replaced it with the Toytec Boss 2.0 for lift purposes but that stock ride was smooth.$.02
  11. Jun 19, 2017 at 8:14 AM
    JBecker
    Virginia
    That's what I noticed most. Less front end dive on hard braking, less body roll, and smoother ride over washboard gravel roads.
  12. Jun 19, 2017 at 8:16 AM
    dually
    dually Low and slow
    I believe the spring differences between models depends on long or short bed.
  13. Jun 19, 2017 at 8:16 AM
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    I'm faced with a similar situation. I have a pup that gets car sick, and it's all the reason I need to rebuild my entire suspension. I also have a bunch of armor coming that going to weigh me down even more.
    I was looking to smitty's lift thread w/ maybe a set of Deaver J66's in lieu of the AAL. I have no clue how this will ride, though.
  14. Jun 19, 2017 at 8:19 AM
    Silentshredr
    Chuck
    16 DclbOr4x4
    Iirc OR models have progressive coils and all other models have linear rate springs. Also the reason the OR will ride stiffer with more preload. Not positive on this but fairly sure
  15. Jun 19, 2017 at 8:22 AM
    techman993
    techman993 Well-Known Member
    Allen
    Pittsburgh, PA
    2018 Cement Tacoma TRD OR
    Tinted Windows B-pillar vinyl delete Tyger Step-Tubes Tailgate decals (Thanks @rrentop!) Boss 2" lift 285/70/R17 Nitto Terragrapplers TRD PRO Rims
  16. Jun 19, 2017 at 8:35 AM
    dually
    dually Low and slow
    According to Toyota parts breakdown, the part number between the OR and SR5 coils are the same.
  17. Jun 19, 2017 at 8:41 AM
    Silentshredr
    Chuck
    16 DclbOr4x4
    Thanks for throwing the facts in, I was wrong
  18. Jun 19, 2017 at 8:58 AM
    dually
    dually Low and slow
    No worries man! :thumbsup:
  19. Sep 20, 2017 at 5:52 PM
    ydnapluk
    ydnapluk Member
    I absolutely cannot stand the low-speed braking nosedive on my '15 TRD OR DBL Cab and have been struggling with the level of suspension upgrade needed to resolve it. I'm not really interested in a lift at this point (don't want to look too doofy with stock wheels and tires)...although leveling the front would probably help with weight transfer and nosedive, so I am interested in bumping the front up a bit in that sense...
    I've been looking at the usual coilover suspects, but my question for Silentshredr and JBecker is whether or not the nosedive and body roll improvements were the result of only a shock upgrade using stock springs, or did you guys also upgrade the front coils along with the shocks?
    Thanks in advance.
    kjp4575 likes this.
  20. Sep 20, 2017 at 9:28 PM
    kjp4575
    kjp4575 Well-Known Member
    Portland OR
    2016 TRD Sport DCSB Prem Tech Package
    I have the exact same question as ydnapluk. I have a DCSB Sport (Hitachi shocks) and would like to soften the ride a little bit. For now, I'm not interested in a lift, but when it comes time to put on new tires I'll probably go larger than stock and will probably want to lift at that time. When and if I lift, I'll probably go a maximum of one and a half inches. I've been looking at the 5100's but should I also consider replacing the coil overs at the same time? Keeping in mind that my primary goal is to soften the ride.
    I also thank you in advance.
    PS I've read so much information on TacomaWorld about suspensions, my head's gonna explode.
