Bilstein vs Eibach
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cappy, Jul 3, 2020.
  1. Mar 2, 2021 at 7:22 AM
    #41
    TacoRoams
    TacoRoams Well-Known Member
    David
    Whittier, CA
    2019 White Tacoma TRD Off-Road
    So you gained 2.25", what is the max you can gain?
    TayTay Ankles likes this.
  2. Mar 2, 2021 at 10:56 AM
    #42
    YE2KA
    YE2KA Well-Known Member
    JB
    19 Cement Grey Tacoma Offroad
    Man idk if I should install it some people say you need a diff some people say no somethings gotta to give lol
  3. Mar 2, 2021 at 1:16 PM
    #43
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO2s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    I was advised by Headstrong Off-road that it’s not needed and a waste of time/money on the 3rd gens.
    YE2KA[QUOTED] likes this.
  4. Mar 2, 2021 at 1:19 PM
    #44
    IrishRed
    Central PA
    Yes, I gained 2.25” of front lift on the first clip. I believe the 3rd clip can provide around 3” of lift but is only recommended for people running heavy bumpers and winches. My truck rides very nice on the first setting.
  5. Mar 2, 2021 at 3:11 PM
    #45
    TacoRoams
    David
    Whittier, CA
    Perfect I am running a heavy bumper.
  6. Mar 3, 2021 at 12:58 AM
    #46
    YE2KA
    JB
    I wishni knew more about this to make a decision seems like everyone is 50/50 yes and no. Thanks for you knowledge though
  7. Mar 5, 2021 at 7:09 PM
    #47
    TayTay Ankles
    TayTay Ankles Well-Known Member
    What a nice ride man. Good call on the Eibach. I've only heard of the 5100s at that price point and almost pulled the trigger on some until I read your post. I definitely wanted something that would raise higher than 2 in to make it worth it. I'm definitely going Eibach now. Any advice?
  8. Mar 6, 2021 at 4:33 AM
    #48
    IrishRed
    Central PA
    Thank you! I’m still very happy with my setup and have no regrets. I’d do it the same way all over again. The Eibach kit is a lot of juice for the squeeze. I can’t really offer you any advice other than don’t hesitate to buy it when you find it in stock. If you have any specific questions, feel free to reach out to me.
    YE2KA likes this.
  9. Mar 6, 2021 at 5:24 AM
    #49
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Hi guys, I have a silly question. When you lift a Tacoma say 2" do you need to install longer brake lines or there is enough slack for over extender. How about the drive shaft ?, or maybe 2" is kinda the max before other alterations must be done?, I suppose the re-gear for the rear diff. Our '17 off road is stock but a bit hight will be nice, don't plan on rock crawling or adding heavy armor just a cap at some point, being able to load it up with camping gear and maybe tow a light boat (Lund 14' with a Honda 25hp).
    Thanks guys
  10. Mar 6, 2021 at 6:59 AM
    #50
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Exactly 5100’s
  11. Mar 6, 2021 at 9:54 AM
    #51
    TayTay Ankles
    Thanks man. I have the same question as Das Taco. Did you have to get a longer brake line with your lift?
  12. Mar 6, 2021 at 10:04 AM
    #52
    TayTay Ankles
    I would like to know this answer too
  13. Mar 6, 2021 at 10:20 AM
    #53
    digitalcarnivore
    digitalcarnivore Member
    06 TRD ACLB 4x4
    A regear is not necessary unless you are put on tires that are much larger than stock. lifting does not affect gear ratios.
    DAS Taco[QUOTED] likes this.
  14. Mar 6, 2021 at 10:40 AM
    #54
    AdventureTaquito
    AdventureTaquito Well-Known Member
    Jose
    20' TRD Sport 4x4 DCLB
    I have 5100’s all around on my 3rd gen and I like it. OEM coils, not OME coils. Just because Bilstien recommends to use the factory coils. 1” block in the rear. No complaints after 9k miles on all kinds of roads. I can’t compare to other brands since this is my first suspension lift. But it was very affordable and install was very easy. I went with this setup because there are is a ton of information on it and it just worked for my needs. Let’s see how long they last
  15. Mar 6, 2021 at 11:26 AM
    #55
    IrishRed
    Central PA
    No. Didn’t have to mess with anything like that. No differential drop. Simple and straightforward. I did have to replace the front needle bearing with the ECGS bushing.
  16. Mar 6, 2021 at 2:32 PM
    #56
    TayTay Ankles
    Perfect! Thanks
  17. Mar 6, 2021 at 2:35 PM
    #57
    TayTay Ankles
    Looks great! What tires are those
  18. Mar 8, 2021 at 4:21 AM
    #58
    YE2KA
    JB
    Why did you opt out of the differential drop? Just preference or you were advised?
  19. Mar 8, 2021 at 8:41 AM
    #59
    IrishRed
    Central PA
    I was advised by Marie & her husband when they were at Headstrong Off-road that the differential drop for the 3rd gens is a waste of time and money because it does very little. The same advice was also given to me by many on here as well.
  20. Mar 9, 2021 at 12:37 PM
    #60
    TayTay Ankles
    How are grade E KO2s on the road though? I'm debating on the 275/70/17 grade E and 265/70/17 grade C. I feel like the 275s will look more aggressive, which is the look I'm going for. However the 265 might not be that noticeable of a difference and have a better ride quality and MPG. Any thoughts?
