Bilstein vs. OME
Discussion in 'Suspension' started by Justin, May 16, 2012.
  1. May 16, 2012 at 9:30 PM
    Justin
    Justin [OP] Well-Known Member
    Justin
    Olivehurst, CA
    2018 4Runner TRD-OR
    Soon..... Very Soon
    I am trying to decide if I want to get Bilstein's on all 4's with adjustable Coilovers or OME setup. I am going to be putting a heavy bumper on at some point so I know I will need HD springs. Any thoughts?
  2. May 16, 2012 at 9:52 PM
    ONEOFMANY503
    ONEOFMANY503 Well-Known Member
    Portland, OR
    2010 PreRunner DCSB SR5
    5100 front at 2.5'', rear leaf tsb and 1.5'' AAL, tinted tails,Race Line Raptors 16x8, Wild Country XTX with mountain snowflake 285 75 16, tow hitch w/brake harness, locks on storage bedsides, tailgate theft mod, heather blower tsb, custom bed rails, black front valance, mud flap delete, 12v full time power, seatbelt buzzer silenced, custom storage behind rear seat, bottom of cab painted, rear view mirror on/off switch, diff breather relocation,
    OME if your going to be putting on a bumper. 886 springs is what you want. OME will be cheaper and you will get the beffier springs.
  3. May 16, 2012 at 10:16 PM
    DevL
    DevL Well-Known Member
    Bilsteins are not adjustable other than acting as a preload spacer. OME is the shock you want and you don't want to preload your stock spring that much. Get 885 until you have a plate bumper and winch... then swap to 886 springs. Get the older OME shocks. The newer Nitrocharger OME are more expensive and ride firmer.
