Bilstein
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dtay4197, Mar 9, 2016.
  1. Mar 9, 2016 at 8:31 AM
    dtay4197
    dtay4197 [OP] Well-Known Member
    Dustin
    silver 2007 trd offroad
    2.5 bilstiens, colormorph retrofit halos and fogs, urd maf cal, Urd tcai, 20x12 mo962, 33x12.50x20 iron man mts
    Instead of spending a thousand dollars on coilovers could I run my current bilstein 5100s set at 2.5 and add a 2" coil spacer to that along with 2 inch aal in rear and be able to clear 33" s?
  2. Mar 9, 2016 at 9:38 AM
    Monster1088
    Monster1088 Active Member
    Arizona
    2019 DCSB OR Tacoma
    I may be wrong since I don't have bilsteins but adding a 2 inch spacer on top of the max setting with the 5100's is a no go, especially if you still have stock ucas. There is no guarantee you will be able to fully clear 33 inch tires without doing some sort of trimming, but everyone's truck seems to be different.
    Your bilstein at 2.5 should give you enough lift to put on a good size tire though.
