Bilsteins @ 2.5 (stock) or OME 887 @ 0
Discussion in '3rd Gen. Tacomas (2016-2023)' started by oliver1539, Aug 7, 2016.
  1. Aug 7, 2016 at 5:41 PM
    oliver1539
    oliver1539 [OP] Well-Known Member
    Kentucky
    2022 Pro/2016 Off Road
    Ok, my current set up is Bilstein 5100s @ 1.75 in the front and 1.5 aal in the rear. The truck rides great with no vibrations or bad road mannors.
    I was wanting to go up, but didn't know if I should reach the 2.5 setting on the Bilstiens or just buy some OME coils (887 or 888) and put the Bilsteins back at 0?
    I've read the Bilsteins would have too much preload on the stock springs and would need new ucas at this setting to achieve a good alignment. Is there an advantage going with the OME set up as far as not needing new ucas and alignment issues?
    I hear people say the OME rides much better than stock. Im trying to hit the 2.5 to 3" range.
    Thanks for the help.
    P S: I've used the search button several times, but couldn't find a specific answer.
  2. Aug 7, 2016 at 6:51 PM
    SothernTaco
    SothernTaco Well-Known Member
    Danny
    Tomball
    Turd Gen
    I'm running the OME 888' and 5100' at 0 up front. I like it a lot and I think it rides much better then stock. It really soaks up the curbs/bumps and has great road manors as well. By the way I'm running stock UCA, however had not had a chance to get it aligned. Talked to a few guys that said it should be no issue after looking at the setup.
    oliver1539[OP] likes this.
  3. Aug 7, 2016 at 6:54 PM
    MSU Taco
    MSU Taco More cowbell
    Roger
    Mississippi
    05 DCLB 4x4
    You're gonna get mixed opinions about control arms at 2-3 inches front lift. If they can't align it you will need to pony up for some.
  4. Aug 7, 2016 at 7:40 PM
    johnnyjunk
    johnnyjunk Lurk more, learn more.
    The Great PNW
    2016 Tacoma TRD Off-Road
    I'm running 5100's on stock springs and it's fine for what I use the truck for which is hauling stuff for work and daily commuting and the occasional forest service road or camping trip. I did however replace my UCAs.
    ChadsPride and oliver1539[OP] like this.
  5. Aug 8, 2016 at 6:08 AM
    oliver1539
    Kentucky
    Thanks for the input! How much lift did you end up with? I wish I would've gone this route in the first place.....
  6. Aug 8, 2016 at 6:10 AM
    oliver1539
    Kentucky
    Yea, I see the already. Not many people seem to have set the Bilsteins at 2.5!
  7. Aug 8, 2016 at 6:13 AM
    oliver1539
    Kentucky
    Do you have them on the 2.5 setting? Is the ride too harsh?
  8. Aug 8, 2016 at 6:43 AM
    0311K1LL
    0311K1LL The Old Breed
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    OME 887 w/Bilstein 5100's, 1.5 AAL, SPC LR UCAs 285/75/r16 Toyo AT2s!
    Buy the 887 and set at 0.
    I wouldn't recommend preloading that much. Buy aftermarket UCA, your alignment will never come out right.
    jsinnard and oliver1539[OP] like this.
  9. Aug 8, 2016 at 6:52 AM
    oliver1539
    Kentucky
    That's what I'll end up doing. How much lift did you end up with
  10. Aug 8, 2016 at 6:57 AM
    0311K1LL
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    I got 2.25 on my access cab 4cylinder
  11. Aug 8, 2016 at 7:16 AM
    johnnyjunk
    The Great PNW
    Yes I have them on the top setting. Ride isn't harsh at all.
  12. Aug 8, 2016 at 9:16 AM
    oliver1539
    Kentucky
    So, I would get a little less with the V6.
  13. Aug 8, 2016 at 9:17 AM
    oliver1539
    Kentucky
    Awesome! That's really all I'll use my truck for, too. Did you need the new ucas or just decided to replace them? What brand did you go with?
    johnnyjunk[QUOTED] likes this.
  14. Aug 8, 2016 at 9:29 AM
    johnnyjunk
    The Great PNW
    It's hard to say if I needed them since I bought them before I lifted my truck, but I didn't want to risk it and have to install them after the fact. I went with https://www.amazon.com/Specialty-Products-Company-25470-Control/dp/B001DC1U4O
    I think which ever route you decide to go as far as lift, after market UCAs are probably a good idea. Just my opinion.
  15. Aug 8, 2016 at 9:49 AM
    oliver1539
    Kentucky
    Thanks for the info! I agree. Better to replace them and not have any issues down the road....... I'll look at the link and check them out!
  16. Aug 8, 2016 at 9:51 AM
    0311K1LL
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    Maybe 2 dead even after they settle. No big deal, you'll have plenty of room to fit up to a 295 or a 255 (33.5ish)
  17. Aug 8, 2016 at 9:53 AM
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    Don't forget about Icon, Total Chaos & Camburg!
  18. Aug 8, 2016 at 9:54 AM
    0311K1LL
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    The total chaos are sweet, they do require more maintainence but are more rugged than SPC LR uca. I got the SPC since I'm not a hardcore wheeler (got my 4wheeler for that). Uniball tend to take more abuse but you have to grease them up often
    oliver1539[OP] and Ihatetacomas like this.
  19. Aug 8, 2016 at 9:57 AM
    0311K1LL
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    Hey sorry I misread. Go with the 888 for 2.5 range.
  20. Aug 8, 2016 at 10:01 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    I carry a lot of weight in my truck, 887's @ 0 gave me just 2" of lift. Running AllPro UCA'S, air bags and Wheelers 3 leaf HD aal. Rides like a truck, stiff but controlled. Can't imagine stock springs @ at the highest setting being any smoother.I get like 18 mpg's with my 285/70/17 tires being easy on it.
