bilsteins 5100 all around
Discussion in 'Suspension' started by chitowntaco, Jan 8, 2015.
  1. Jan 8, 2015 at 7:59 PM
    chitowntaco
    chitowntaco [OP] Well-Known Member
    Robert
    Chicago
    2015 DCSB TRD Sport
    Who uses billies 5100 all around on stock springs? any complaint?
    I'm trying to level the truck and add a small lift as well to install 18" wheels. I like the look of 1.5 lift in front. Ive never lifted a truck before so Im a total nooby.
    Help and recommendations greatly appreciated.
  2. Jan 8, 2015 at 8:00 PM
    chitowntaco
    Robert
    Chicago
    2015 DCSB TRD Sport
    or should I use blocks in rear instead of bilsteins?
  3. Jan 8, 2015 at 8:16 PM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    What truck you got? Go check out some other threads. You won't find many who will tell you to go for blocks. You can level the truck with bilsteins in the front, you can fit 18's depending on tire size
  4. Jan 8, 2015 at 8:22 PM
    ROAD DAWG
    ROAD DAWG Well-Known Member
    birmingham,al
    10 trd prerunner
    debadged,procomp 7105 wheels,,kc slimlites,n-fab light bar,predator step bars,baja roof rack and light cage,hella 500 black magic,5100's(f/r) @.85,tsb rear,nitto terra grapplers(265-65-17)
    i'm running 5100's all around(purchased from downsouth motorsports)fronts are set @.85,first notch past stock,i'm on "tsb" leafpack on the rear...the truck is solid and stable and actually handles better than stock,but it can be a tad rough on bad city streets,on smooth interstate it's really nice...I've seen non-lifted tacomas on 18's at the dealership lot,just can't get crazy with the tire size,originally I got a tad more than .85 lift from the 5100's,i didn't want to cut to clearance tires so I stayed with the stock size(265-65-17),and yeah,they look puny,but they don't rub.
  5. Jan 8, 2015 at 9:27 PM
    chitowntaco
    Robert
    Chicago
    2015 DCSB TRD Sport
    I have a 2015 tacoma trd sport on 17's. Thanks for the replays so far.
  6. Jan 8, 2015 at 9:28 PM
    chitowntaco
    Robert
    Chicago
    2015 DCSB TRD Sport
  7. Jan 8, 2015 at 9:29 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    What size tires are you trying to run?
    I haven't heard many complaints about 5100s on stock coils. Heaps better that a level/spacer lift..
  8. Jan 8, 2015 at 9:30 PM
    chitowntaco
    Robert
    Chicago
    2015 DCSB TRD Sport
    Could you post a picture of your truck? or attach to a build thread if you have one.
    Thank you
  9. Jan 8, 2015 at 9:31 PM
    chitowntaco
    Robert
    Chicago
    2015 DCSB TRD Sport
    i want too run 275/60/18 on my truck after I level it. I don't want to sacrifice to much of stock ride because I really like it.
    Thanks
  10. Jan 8, 2015 at 9:33 PM
    chitowntaco
    Robert
    Chicago
    2015 DCSB TRD Sport
    Who do you recommend in chicago area to help with installs and parts?
    Thank you
  11. Jan 8, 2015 at 9:36 PM
    geekhouse23
    http://www.chitown4x4.com/index.html
    They use these guys for installs:
    http://www.autopractor.com
    Could always hit up Joe, the owner of Chitown 4x4 and see if he would be willing to host a mod day. Bring your own tools or ask someone to bring some tools you need and we can lend you a hand :D
  12. Jan 9, 2015 at 7:35 PM
    chitowntaco
    Robert
    Chicago
    2015 DCSB TRD Sport
    Heaps? whats the full name don't find anything under heaps.
    Thanks for all your help
  13. Jan 9, 2015 at 8:04 PM
    Iwilltaco
    Under development
    Depending on how your truck sits, leveling it out will take setting fronts at .85 or 1.75. Either one works with stock coils and the ride won't be sacrificed. As far as tire size, I don't know about the width, depends on the wheel offset I guess.
