Bilsteins on 2012 DCLB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 757 Taco, Apr 27, 2012.
  1. Apr 27, 2012 at 8:41 PM
    757 Taco
    757 Taco [OP] StormTrooper
    Tyler
    757
    2012 DCLB TRD Sport 4x4 Super White
    - Digital Fit WeatherTechs - Recovery Hitch Shackle - Tinted Windows 20% Front, 5% Rear Window - White 48-LED Dome Light - Two 12-LED Map Lights - Sylvania Silverstar Ultra Headlight Bulbs - LED License Plate Bulbs -20" LED Lightbar - 886 Reverse Light Mod - FogLight Anytime Mod - AFE ProDry S Drop-In Air Filter - OME 885x Coils w/ Bilstein 5100's @ 0" - Rear Bilstein 5100's - Wheeler 1.5" Progressive AAL - TRD License Plate Brackets - Front Recovery Shackle - Black LED Tail Lights - Toyota Bed Mat - LED Third Brake Lights - Sockmonkey Bedside Decals - 285/75/16 Goodyear Wrangler Duratracs - Procomp 7089's - Rear Diff Breather Mod - FlyzEye V1 - Grillcraft w/ FJ Emblem - Removed Sway Bar - TRD Auto Shift Knob - TRD Offroad Transmission Skid - Hose Clamp Mod
    So i know its been covered a lot but really wanna do a mild lift on my new 2012 DCLB TRD Sport. If I set the bilsteins at 2.5 in the front on the stock coils + rear 5100's and a wheelers 1.5 inch AAL will I be disappointed with the ride? Also is an alignment necessary? Whats everyones opinion? BTW it'll be like $400 for this setup
  2. Apr 27, 2012 at 9:19 PM
    757 Taco
    Tyler
    757
    your right man. just dont want a real bad ride on this. but definitely cant be worse than the last taco, lol the new one just rides soo smooth :cool:
  3. Apr 28, 2012 at 12:20 AM
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    As bandit said...we will be spending lots on these over the years....i have icons in my future as well which is why i just threw the 3" toytec spacer lift on for now....very cheap but good quality...no change in ride and it allowed me to run 285s....i will definetly be upgrading later but u cant beat the price of 250$ for 3" of lift.
  4. Apr 28, 2012 at 1:56 AM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    Love my 5100's. Similair to your sstock billi's but on steroids. setting at 2.5 will change your ride w/ stock coils. should ride a tad more stiff. Anytime you change your suspension you will need an alignment.
  5. Apr 28, 2012 at 2:17 AM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    With stock coils at 2.5 it will ride stiffer then stock, you could just get the billes and set them at 0 and add some ome 885x coils and you will be just about 2.5, but the ride will be smoother...
  6. Apr 28, 2012 at 3:30 AM
    Executive
    Executive Conservative
    Peabody, Massachusetts
    2012 DCLB TRD Sport
    I am looking at a similar set up. 5100s on all corners, front set to 1.75, and spacer on driver side to correct driver side lean. I'm mostly looking to remove rake and level stance. Would I be better off spending more for pre assembled coil overs up front for a quicker easier install? I would prefer to keep or improve the factory ride. Also, this set up would allow metro increase lift with front adjustment and an AAL out back late on if I wanted to run larger tires.
    Tacoma world has not let me down yet, what do you guys think?
  7. Apr 28, 2012 at 3:34 AM
    BulletToothTony
    If your just wanting to level it out then stick with the billies, just take off your stock shocks and either rent a spring compressor or take it to your local auto shop and let them do it.
    Also with them set at 1.75 i think you can just clear 265's (somebody correct me if im wrong) if you set them at 2.5 you can clear 285's...
  8. Apr 28, 2012 at 9:31 AM
    757 Taco
    Tyler
    757
    thanks for the info. anybody else have experience? bump
  9. Apr 28, 2012 at 9:43 AM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Does your truck have a 4 leaf pack?
  10. Apr 28, 2012 at 10:57 AM
    757 Taco
    Tyler
    757
    yeah man
  11. Apr 28, 2012 at 11:12 AM
    senor taco
    Monterey Bay, Ca
    Then I would try just leveling the front with 5100's and elbach coils. You will probably get a smother ride that way. If the front is too high for your likingn you can always get an AAL afterword. My truck has 5100's all around with the front set @2.5 and a 2" AAL and the rear sits a little too high for my liking( it rides pretty stiff too)
  12. Apr 28, 2012 at 11:15 AM
    seric007
    seric007 Well-Known Member
    i'd pass on the firestone lifetime alignment, you'll just spend a lifetime of having the alignment done wrong.
  13. Apr 28, 2012 at 11:48 AM
    757 Taco
    Tyler
    757
    yeah not a bad idea. what do you think about the rear. get 5100's or save the money. also do you think ill be okay without uca's for a while
  14. Apr 28, 2012 at 11:49 AM
    757 Taco
    Tyler
    757
    :rofl:
  15. Apr 28, 2012 at 4:27 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
  16. Apr 28, 2012 at 5:13 PM
    757 Taco
    Tyler
    757
    the hell you looking at mang :p
  17. Apr 28, 2012 at 5:32 PM
    senor taco
    Monterey Bay, Ca
    Its up to you but I like to have the same shocks all around. I don't think you would need ucs unless you lift over 2.5".
  18. Apr 28, 2012 at 7:08 PM
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    J00. I be a :spy:in
  19. Apr 29, 2012 at 5:45 PM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    I have the 5100's all the way around, front at 2.5 and 885's. Rear has Toytec AAL. Running 285 17's and get it off road as often as possible... Though it is a pre runner. It rides like a truck... Stiff. HOWEVER, I can slam into holes, ruts, whatever... And it takes it like it should. I like the ride... Wife thinks its too stiff... But I think her 2012 Highlander is too soft! :D
  20. Apr 29, 2012 at 7:01 PM
    big sky
    big sky Well-Known Member
    Montana
    2012 TRD Sport DCSB 4x4
    if you're looking to level your truck another option is adding Eibach springs to your oe Bilstein dampers- you'll get 1.6"-ish of lift, just about the exact amount to get level
    the other option as someone else mentioned is 5100's set at 1.75", you will be pre-loading the oe springs which while not ideal, shouldn't be too bad
    if a guy can swing it- aftermarket springs and 5100's set at 0 would be a great option
