Bilstein's or not?
Discussion in 'Suspension' started by camo junkie, May 2, 2013.
  1. May 2, 2013 at 11:31 AM
    camo junkie
    camo junkie [OP] Well-Known Member
    Greg
    Kansas
    2014 Tacoma Sport 4x4
    3" lift OME lift 887 coils, LR UCA's, 16" Stealth Custom Series Wheels and 265/75/16 Duratrac Tires
    I have a 2008 TRD Off-Road Access Cab 4x4 that I though I want to lift 2.5" in front with 5100's and 1.5" AAL in the rear with new Bilstein's in the rear. I have done many searches on the subject but only seem to find a lot of confusing opinions on the matter. I use my truck as a daily driver and currently run 265\75\16 with a little rubbing but might want to move up to 285's down the road. I occasionally go off road but generally nothing very serious & don't really want to lift more that 2.5" to 3" at most.
    Here are my questions:
    • Will the ride still be comfortable with the Bilstein 2.5" lift option
    • Will I need new UCA's if set at 2.5"
    • Will I need a differential drop
    • Will I be able to get the frontend properly aligned
    • Could the 5100's set at 2.5" damage anything
    • Should I consider a different approach to gain the desired lift
    Sure would like to get some expert opinions on the matter
  2. May 2, 2013 at 1:13 PM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    Get a set of springs and do not preload the 5100's.
  3. May 2, 2013 at 1:16 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    OME 3"
    with icon or wheelers progressive aal
    preloading offroad coils will give u a rough ride.
    UCA at 2.5 are a toss up, but Id budget them in just in case.
    Im no expert, but I rode in chris' truck with the OME coils and shocks and it was comfortable.
  4. May 2, 2013 at 7:37 PM
    camo junkie
    Greg
    Kansas
  5. May 2, 2013 at 9:16 PM
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    • No
    • Possibly
    • General consensus on here is that diff drops on 2nd gens don't make much of a difference on the angles plus putting the diff in harms way. Search diff drop and there are many threads on it.
    • With UCA's yes, without new UCA's it might not be perfect. Every truck is different
    • Damage No. Cause more wear on parts Yes anytime you lift it can.
    • I have bilsteins set at 1.75, the ride is stiff enough. Any higher you should be considering lift springs.
  6. May 2, 2013 at 9:27 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    not
    and I concur about the diff drop.............does more damage than good
    talk to MJP2 about it
  7. May 3, 2013 at 7:45 AM
    camo junkie
    Greg
    Kansas
    Thanks Ronn your information was very helpful
  8. May 3, 2013 at 3:17 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    No problem
