Bilsteins shocks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lsutiger1, Feb 26, 2017.
  1. Feb 26, 2017 at 2:18 AM
    lsutiger1
    lsutiger1 [OP] Well-Known Member
    Wilmington, NC
    2017 BLACK TRD OFF ROAD DCSB
    3inch lift,285/75/16 on method 301's
    Ok just traded my 14 in for a 17. Dealer is switching my bilsteins and 3 leaf aal to my new truck. Any pictures set at 1.75 front and aal in back with 2017 TRD OR? Also was thinking about since I'm getting them switched over for free raising the front up to 2.5. What ya think?
  2. Feb 26, 2017 at 3:59 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    He said already swapping them? Or you're going to get him to do it?
  3. Feb 26, 2017 at 4:32 AM
    ecotecin
    ecotecin Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    I thought the shocks from a 14 wouldnt fit a 17, i thought it took a different shock or something.
  4. Feb 26, 2017 at 4:35 AM
    lsutiger1
    Wilmington, NC
    I thought it was 05 and up would fit
  5. Feb 26, 2017 at 4:37 AM
    Markc1024
    Markc1024 Well-Known Member
    Hold off on going too high unless you want to replace the driver side front diff bearing with the ECGS bushing. Personally, I'd drive it stock for a few months just to ensure no issues and then once you're feeling like no initially warranty issues, then look at replacing the shocks/AAL.
    sig916 and bobrown14 like this.
  6. Feb 26, 2017 at 4:37 AM
    ecotecin
    WV
    Im not 100 percent sure, i thought i was reading that the mount was a little different on the 16's and up. There is a thread on it somewhere on here, ill see if i can find it. Unless they figured out what it was, it seems i read that on here.
  7. Feb 26, 2017 at 4:43 AM
    lsutiger1
    Wilmington, NC
    Yea I would definitely like to know if they fit. Dealer would be doing the swap!
  8. Feb 26, 2017 at 4:43 AM
    ecotecin
    WV
    Well i guess i mayhave been wrong, i cant seem to find anything on here now, maybe it was just the rear shocks that didnt fit, im not for sure, but i would talk to like @HeadStrong Off-Road or @ToyTec Lifts and see if they know for sure. They would 100 percent know before i would.
    HeadStrong Off-Road likes this.
  9. Feb 26, 2017 at 4:44 AM
    lsutiger1
    Wilmington, NC
    I will do appreciate it
  10. Feb 26, 2017 at 4:44 AM
    ecotecin
    WV
    But i am most certain if you go to 2.5 you will need UCA to get a good alignment.
  11. Feb 26, 2017 at 4:47 AM
    lsutiger1
    Wilmington, NC
    Don't want that!
  12. Feb 26, 2017 at 8:08 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    You can swap your old in for new... can't be sure why you would want to tho... put a 3 year old suspension on a new truck?? The stock suspension will be well NEW.. and probably ride better than your old suspension.
    Btm line - they will fit and that's why the dealer will be willing to do the swap for you. The suspension on an OR are Bilstein 4600s the same valving as 5100s which is what you likely have on your 14.
    The OR will already have 1" lift over your stock 14 from the factory with the same ride but NEW.
    Keep the stock suspension on the new OR and upgrade later.. you can get Bilsteins and AALs for around $800 NEW.
    They just came out with a new Bilstein shock for the Gen3 about a month or 2 ago, before that we all used the gen2 version 5100s with new springs to do the lifting.
    I'd stick with stock and upgrade later.
  13. Feb 26, 2017 at 8:15 AM
    lsutiger1
    Wilmington, NC
    Yea that might be the best thing! Haven't thought about that way. Truck will not be here until tomorrow so I have time to change my mind
  14. Feb 26, 2017 at 8:39 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Yeah new suspension going to ride better than a 3 year old one... you'll see.. and love it. Then mod after like we all do... hahahaha you can save your money till you're ready to lift.
