Bilsteins with the TSB
Discussion in 'Suspension' started by pskubota, Nov 10, 2008.
  1. Nov 10, 2008 at 4:54 PM
    pskubota
    pskubota [OP] Wife Wants to Drive My Tacoma!
    Concord, CA
    2008 SR5 4x4
    Aries Bull Bar, Recon LED Light Bar, Side Steps, Bed Divider, Door Lock Beeper
    I have an 08 Double cab 4x4, non TRD. I will be getting the Suspension TSB done as soon as I have a little time to bring the truck down to the shop. I was wondering if you think the dealer would install Bilstein shocks instead of the regular shocks they're supposed to come with if I paid the extra parts cost. (1) Do you think I should go with the Bilsteins? (2) How much more do you think the Bilsteins would add to the TSB? and (3) Does it cost any more to install these types of shocks? Thanks for the replies.
  2. Nov 10, 2008 at 6:01 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I've heard some dealers will do it, not all. Charge will be anywhere from 200 to 300 extra.
  3. Nov 10, 2008 at 6:07 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Have you looked at the TSB?
    (sorry, but I don't have time to look it up for you)
    I'm pretty sure the TSB requires them to install the TRD shocks (bilsteins) in the rear only if you don't already have them.
  4. Nov 10, 2008 at 6:18 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Yep - for the TRD, they only do the rear. That's what they did on mine. I even "marked" my front shocks before and checked them after - no change... :)
  5. Nov 10, 2008 at 6:19 PM
    oldtacomaguy
    Dave
    SE Conn.
    Janster, If your truck is not a TRD, they are supposed to put 4 new bilstein shocks on, If it is a TRD, you only get the new leaf springs.
  6. Nov 10, 2008 at 7:03 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    yup yup....mine was a trd and they still swapped 4 shocks on mine....i didnt complain
    • Non-TRD Option Package Truck
    OP CODE DESCRIPTION TIME OFP T1 T2
    SU7003 Rear Spring Assembly (Both Sides) 1.4
    Combo A Front Shock Absorber (Both Sides) 1.5
    Combo B Rear Shock Absorber (Both Sides) 0.6
    Combo C Alignment 1.2
    Combo D Front Toe-in 0.1
    Combo E Front Camber 0.2
    Combo F Front Caster 0.2
    48210
  7. Nov 10, 2008 at 8:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    When I hasd the TSB done I specifically told them NOT to touch my shocks. :D
  8. Nov 10, 2008 at 10:26 PM
    pskubota
    Concord, CA
    2008 SR5 4x4
    I looked at the TSB but couldn't tell what kind of shocks they would put on. I assumed the same kind that originally came with my non-TRD (non Bilsteins). Can you tell from the TSB that they are indeed Bilsteins that they have to replace them with?
  9. Nov 10, 2008 at 10:28 PM
    jhodge83
    SC
    they will be replaced w/ the bilsteins that come on the trd trucks
