Bilstien 5100 or OME 881 shocks?
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, Feb 22, 2011.
  1. Feb 22, 2011 at 9:48 AM
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Im planning on getting some 881's for up front (coil and shocks) and 5100's out back with an AAL.
    Would it be better to get Bilstiens up front as with the 881 coils or are the OME shocks good enough?
    Thanks.
  2. Feb 22, 2011 at 9:50 AM
    98tacoma27
    Ben
    Not Beech Creek
    If you're going to get the 881 coil, you should get the OME shock. They are designed around each other. My $.02
  3. Feb 22, 2011 at 12:00 PM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    OME shocks are good, they cost more but better. bilsteins are still good too.
  4. Feb 22, 2011 at 3:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im running 881's with 5100's set on "0"...........about to take them off and put on my ome nitrochargers soon as they come in. i dont like the ride of the 5100 coupled with the 881 coils.
  5. Feb 22, 2011 at 6:12 PM
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    I'm debating going with the 881 and 5100 set at 0" set up, what is wrong with the ride? Too rough?
  6. Feb 22, 2011 at 6:20 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    It'll ride great at first....but on really rough road.........no good. Those struts are too progressive for those coils. I have close to 20k on my setup now and I'm about to dump it.
  7. Feb 22, 2011 at 7:01 PM
    TacomaGus
    Gus
    Morgantown, WV
    i have the 5100's currently at the highest setting, but after a year and a half they've settled to about 2 inches of lift. They give a bit of a jarring ride on rough roads, so thats why i was wondering whether the 881's would help out with the ride since the shocks wouldn't be loaded at all. What do you mean by progressive?
  8. Feb 22, 2011 at 7:02 PM
    rmahoney2013
    rmahoney2013 Well-Known Member
    Robert
    California
    Speedway Blue Tacoma
  9. Feb 22, 2011 at 7:10 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    stiffer. and the 881 is already a medium spring. it'd be alright with a bit of weight to soak some of it up.............but im going with a set of nitrochargers...as they are valved for those springs.
  10. Feb 22, 2011 at 7:16 PM
    TacomaGus
    Gus
    Morgantown, WV
    thanks for the info man, the springs would be even stiffer on mine i'm assuming (4cyl ext cab) compared to your V6 double cab due to even less weight. I may just stick with the 5100's and stock coils
  11. Feb 22, 2011 at 7:20 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    may be a good idea man.
  12. Feb 22, 2011 at 7:24 PM
    TacomaGus
    Gus
    Morgantown, WV
    I'm just still torn b/c i just can't see how the 881's with the 5100's not loaded down, wouldn't be an improvement over a loaded shock and 160k mile old coils
  13. Feb 23, 2011 at 1:01 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Thanks for the input. Ill stick with the OME setup and just put Billies on the rear.
  14. Feb 23, 2011 at 1:29 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    go with the billies they are monotube design and are much more reliable. ome is designed around their springs but they are quicker to overheat and the hydraulic oil can "foam" resulting in fading.
    on a side note im using the 883 coils which have a higher spring rate than the 881s and bilsteins and im happy with the ride
  15. Feb 5, 2019 at 3:15 PM
    steve2267
    steve2267 Small Mammal Fire Support Team
    Colorado
    04 Double Cab Tacoma 3.4L 4WD/TRD
    Resurrecting an ooooold thread.
    I have shot almost an entire day crawling through (feels like) hundreds of posts about OME 881 springs with 5100 shocks, OME vs 5100, etc. This is the ONLY post I have so far come across claiming Bilstein shocks are much more reliable than OME Nitrochargers. Also, I do not recall many, if any, other posts stating or claiming that OME Nitrochargers fade because "they are quicker to overheat and the hydraulic oil can "foam" resulting in fading."
    Perhaps a monotube shock is a better design than however the Nitrochargers are designed. As an engineer I am not trained nor versed in shock design, nor have I studied it, so I cannot comment. However, I can ask... anybody out there have had issues with Nitrochargers "fading"? Or other issues with Nitrocharger shocks? Everything I have read on here... I'm not sure I've even read one bad post about full OME setups. (And I cannot recall anyone posting about how they ran Nitrocharger shocks with springs other than OME.)
    Anyone? Buehler? Buehler?
