Bilstien 5100's In the rear ? '07 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DLPerry432la, Jun 26, 2009.
  1. Jun 26, 2009 at 1:31 PM
    DLPerry432la
    DLPerry432la [OP] 07La
    Dave
    Downtown LA
    07 Pre-Runner SR-5 TRD Off Road 2 X 4
    All Eligible Factory TSB's performed. Sway Away Race Runner Adjustable Front Coil-Overs, Bilstein 5100's in the rear with Deaver 3703-K33 Leafs, Camburg UCA's and 4" Drop Spindles, Pro-Comp Extreme 285/75/16 Tires 33", on Moto Metal Wheels,AIRAID Cool Air Intake, Pioneer 6100 AM/FM/CD/Satellite Radio, HID Headlamps Hi-/Lo
    I have installed Adjustable Coil-overs in the front with Billy 5100's as a kit from Downey Off Road. This gave me a 3"+ lift in the front.
    The rear Leaf TSB has been performed already which gave me about 1½" lift and a bit more tongue weight capacity, however, I want to Add A Leaf, and install 5100's in the rear..
    Anyone have any suggestions as to which AAL product is the best.. I haul (2) dirt bikes regularly (Plus Gear, Easy UP, Fuel, etc, and sometimes a trailer with a sand rail) which puts me on the bump stops. ALso need to know which of the 5100 series I need to order.
    Appreciate some expert help.
    :eek:
  2. Jun 26, 2009 at 1:32 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    toytec has an aal for the tsb springs
  3. Jun 26, 2009 at 1:35 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    How much was the coil overs at downey?
  4. Jun 26, 2009 at 1:35 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    If you're going that much you may wanna look into 5125s for the rear.
  5. Jun 26, 2009 at 2:01 PM
    DLPerry432la
    Dave
    Downtown LA
    Been a while, Under a grand.. The kit Uses 2004 4-Runner springs.. The ride is pretty decent.. Much better than the Spacer I had over the original coil.
