Bilstien height ajustment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SR5 BRI, May 18, 2017.
  1. May 18, 2017 at 3:02 PM
    SR5 BRI
    SR5 BRI [OP] Brian Good Sport
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    Ok so I am getting some 5100s and 887 coils next week and what I am trying to achieve is littl better ride with minimal lift . What is the setting I should set the front struts at.
  2. May 18, 2017 at 3:04 PM
    LoMa
    LoMa Well-Known Member
    2016 Tacoma TRD Sport AT MGM
    The bottom notch will yield approximately 2 inches and change.
  3. May 18, 2017 at 3:13 PM
    wirenut
    wirenut I like this place
    Andrew
    NH
    98’ T4R
    OME/5100 - 300lb 3.5” loft setup Prinsu 3/4 rack
    I got exactly 2" with this in mine.
  4. May 18, 2017 at 3:15 PM
    SR5 BRI
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    Ok guys just wanted to double check before installed. How differant is the ride on the street
  5. May 18, 2017 at 3:16 PM
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    0- to get the "best" ride according to several members on the site. Some members have went up to the first not notch to get additional height but did not mention any increase in stiffness etc. if you want the same ride but a little higher go with the 888 Springs, which is the same spring rate but just longer. The OME Springs are not designed to be preloaded according to ARB USA rep.
  6. May 18, 2017 at 3:19 PM
    SR5 BRI
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    Thanks clay I was looking for about 2in of rise not anymore . Thanks
  7. May 18, 2017 at 3:28 PM
    Clay7160
    Seems that's the average 2 to 2.25 inch
  8. May 18, 2017 at 3:30 PM
    SR5 BRI
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    Thanks clay I thinkin with that brushgaurd on my truck it will probly be about 2in. Or alittle under . When should yours be in
  9. May 18, 2017 at 3:46 PM
    Clay7160
    If it's a little too low for you you could always add a quarter inch spacer at top it'll give you about a half an inch , I don't see a brush guard bringing the front and down too much ,it probably weighs 50 pounds , I think you'll be fine getting you 2 inches.
  10. May 19, 2017 at 9:08 PM
    Shugster2
    Shugster2 Well-Known Member
    Texas
    2017 Quicksand DCLB TRD OR 4x4
    You can do that safely? Adding a 1/4" spacer to the 5100's with 888's that is?
  11. May 19, 2017 at 9:17 PM
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    2wd or 4x4?
  12. May 19, 2017 at 9:22 PM
    Clay7160
    To either the 887 or 888 , several people do it , others go up the 1st notch on 5100 on 887 , could work on 888 but OME says it is not recommended to run their springs that way. Also people normally run a 1/4" inch spacer on left front on top to alleviate Taco Lean , but my opinion a OME trim packer would free up top hat to add 1/4 inch spacer to both sides of extra height is wanted or needed.
