Bilstien help!
Discussion in 'Suspension' started by esimmons, Feb 9, 2011.
  1. Feb 9, 2011 at 8:48 PM
    esimmons
    esimmons [OP] Well-Known Member
    Evan
    Kannapolis, NC
    2007 PreRunner
    Nerf Bars, Bull Bar
    I need help under standing bilstien, do they come stock on trd tacomas (not 5100 series)? I do not have a trd package, but I was wondering if I could get the front and rear shocks of the 5100 series and reuse my factory shock? Also I was wondering if I need the differential drop, it says for 4X4 which I do not have, but it is a pre runner which has the 4X4 set up
  2. Feb 9, 2011 at 8:52 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    the billies replace the stock shocks. Do you mean stock springs? if so, then yes.
    the 5100s are for 6 lug. which is prerunner or 4x4
  3. Feb 9, 2011 at 8:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Spend some time reading the site. You can use the 5100's, or the stock, but not at the same time. Also, If your not 4x4, then you dont have a front diff.
  4. Feb 9, 2011 at 8:53 PM
    DonnoD
    DonnoD Well-Known Member
    don
    las vegas
    07 dc 4x4 v6
    the 5100s are the shocks youre just gonna have to reuse your factory springs and no you wouldnt need a diff drop because you dont have a diff up front
  5. Feb 9, 2011 at 8:54 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Do you know of anyone that is mechanically inclined? I say this not to be rude but it would be a benefit to you if they could look at your truck with you and explain what the different components are. We could type a big long explanation and maybe add pics but in the long run I think it would be better for you to see it first hand.
  6. Feb 9, 2011 at 9:06 PM
    esimmons
    Evan
    Kannapolis, NC
    2007 PreRunner
    Nerf Bars, Bull Bar
    Yes I did mean reuse my factory spring, not factory shocks. Yes I do have people that would be more than happy to walk me through these things but the thing is, they do not know about specific products that I have questions about such as above.
