bilstien shock prices
Discussion in '2nd Gen. Tacomas (2005-2015)' started by madcatter, Apr 15, 2010.
  1. Apr 15, 2010 at 5:47 PM
    madcatter
    madcatter [OP] Well-Known Member
    western pa
    2010 tacoma
    jl audio stealthbox jl audio slash g2-500/1v2 good year dura-tracs jl audio g-class 50wattX2amp mb quart 5 1/4" rear matted mb quart 6.5 comp.set lotsa dynamat 4ga amp kit 16 gauge wire kit control knob on dash pioneer avic-x910bt in dash navigation dvd playback sirus tuner/bus interface built in blue tooth toyota environmental package leaf tsb weather tech floor liners yellow wire mod gray wire mod compartment bed lights added tie down d rings
    i just had my tsb done on my 2010 double cab and now am thinking of getting the billies,according to their website it looks like the fronts are part number-be5-c475-h0 and the rears are be5-c476-h6.can another verify this?also where can they be purchased at online.
    is all i need the shocks???nothing else special????
  2. Apr 15, 2010 at 5:54 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    I just replaced the fronts, already had the rear replaced with the TSB (SR5)
    Its been a while so i dont have the part numbers handy
    Did you measure the back prior to the TSB? And measure it now?
    This way you will know how much lift gave you.
    You will want to remeasure also just prior to installing 5100's.
    I got 1.5 inches of lift from TSB, but about a week later when i went to install the 5100's, i remeasured and i was only sitting 1 inch higher instead of the 1.5.
    So i set my 5100s at .85 instead of the 1.75 i originally planned to.
    The shocks are just a replacement, you will need a spring compressor for the front install.
    Found removing the sway bar made it easier.
  3. Apr 15, 2010 at 5:55 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Try toyteclifts.com or downsouthmotorsports.com. Both give discounts to TW members and most here are very familiar with them. Very helpful companies..
  4. Apr 15, 2010 at 5:55 PM
    DBZ 2010
    DBZ 2010 Well-Known Member
    Kahului, Maui
    2010 Wht Dbl Cab TRD Off Road PreRunner
    Gaylord TL Series Tonneau, 3 TSB's (Trans Re-flash, Rear Leaf Springs, Intermediate Steering Shaft), 5100 Bilsteins x 4 set at 1.75, Silver TRD FJ 16 inch Wheels, Wet Okoles
  5. Apr 15, 2010 at 6:11 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
  6. Apr 16, 2010 at 6:30 AM
    madcatter
    western pa
    2010 tacoma
