bilstien5100 clip position?
Discussion in 'New Members' started by johnnymac84x84, Aug 30, 2015.
  1. Aug 30, 2015 at 5:51 PM
    johnnymac84x84
    johnnymac84x84 [OP] Member
    05 tacoma trd
    Beat n dented
    I'm waiting to install the 5100's in my 05 v6 access cab with the eibach coils. What clip position do I want for the full three inches. Toytec web sites confusing. Toytec says second clip from bottom? So with the coils can I go past three inches? With stock coils use the top clip for the full three? SOS install time aproaches
  2. Aug 30, 2015 at 5:56 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Not supposed to preload those coils beyond the second setting.
  3. Aug 30, 2015 at 6:00 PM
    johnnymac84x84
    05 tacoma trd
    Beat n dented
    Ok so will that second clip give me the full 3 of lift? And what will happen if do run more preload?
  4. Aug 30, 2015 at 6:02 PM
    T4RFTMFW
    Depends on your coils, what is the lift of those coils?
    It will likely ride terribly and void your warranty on your shocks, among other things I've not yet heard of.
  5. Aug 30, 2015 at 6:04 PM
    T4RFTMFW
    I wouldn't try to bandaid too short of a lift coil by preloading them all to hell.
    You can buy OME 887 coils that are actually 3 inch coils for $160. You could sell the Eibachs and run the 5100s at 0 setting which would be the best ride. Do you have UCAs?
  6. Aug 30, 2015 at 6:04 PM
    johnnymac84x84
    05 tacoma trd
    Beat n dented
    I have the 620lbs coils from toytecs 5100 kit
  7. Aug 30, 2015 at 6:05 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Second from bottom
  8. Aug 30, 2015 at 6:06 PM
    T4RFTMFW
    Both Eibach coils are 620 lbs AFAIK.
    What is their lift height? I think they have 1.6 and 2.somethings.
    It doesn't really matter anyway, you still shouldn't go beyond .85 (second setting).
