bilstien's 5100 noob question?...
Discussion in 'Suspension' started by Peter559, Feb 5, 2012.
  1. Feb 5, 2012 at 12:36 PM
    Peter559
    Peter559 [OP] Well-Known Member
    just got these rear 5100 in and was going to install but realized they were the same length as the stock TRD OR billies... aren't these suppose to be a bit longer than the stock ones or are they the same length? The salesman said that they are supposed to be longer in length compared to the stock before i bought them... dont have the stock one next to it to compare length but they are the same length...check it out and let me know...
    thanks in advance!
  2. Feb 5, 2012 at 1:21 PM
    Squaretail
    Squaretail Well-Known Member
    New Hampshire
    08 V6 Black Blurr
    They don't add any extra lift from your stock shocks....I just put my lift in yesterday. They looked pretty similar but didn't compare them side by side.
  3. Feb 5, 2012 at 1:22 PM
    acdronin
    acdronin Well-Known Member
    They are gonna ride a lot better than the stock shocks
  4. Feb 5, 2012 at 2:47 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    I'm pretty sure they are the same travel wise as stock. That's primarily why they say they're good up to 1" lift. Any more lift than that and your loosing down travel. They are valved way better than the TRD shocks, you'll be happy!
  5. Feb 5, 2012 at 2:53 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    5100 rear shocks don't add any ride height to your truck. No rear shock does.
    If that's what you're looking for, you need to add either an "add a leaf" to your leaf pack, a block between your springs and axle, or a replacement leaf pack.
    Now, if you're planning on doing those things, you may want a slightly longer shock than the 5100s that you've purchased. Depends on how much height you're planning on adding.
    5100s have been known to fail due to over-extension.
    However, the opposite case is more likely, failure due to bottoming out the shock before you hit the axle bump stop. So use caution here.
    Short answer:
    If you're leaving it stock or going with a 1" block or 1.5" add-a-leaf, I'd just install the shocks you already bought, and call it a day.
  6. Feb 5, 2012 at 7:28 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    On DSM it says they recomend these shocks for a 2" lift I believe. I dont think you need to worry about it for a mild lift. Go check out dsm to be sure
  7. Feb 5, 2012 at 8:37 PM
    Peter559
    thanks for all the replies guys... i feel like an idiot:) i forgot to mentioned that i have an AAL installed too... i thought that the 5100 were suppose to be longer to increase the down travel...but if it doesnt increase the down travel, i kind see it as a waste because i like the way my car rides already...
    thinking about just refunding these and just get real suspensions:D
  8. Feb 6, 2012 at 10:38 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Nope, they are for stock to mild rear lifts only. They are no longer than stock.
  9. Feb 6, 2012 at 7:45 PM
    Peter559
    they are 26.5 inches... does anyone know if theres any that is 30 inches long? and if it was 30 inches, will it fit?:confused:
  10. Feb 7, 2012 at 6:08 AM
    TexasTacoma37
  11. Feb 7, 2012 at 10:41 PM
    Peter559
  12. Feb 7, 2012 at 10:45 PM
    Peter559
    Anyone knows if the eye to eye shocks work on our trucks?
    Since our shocks are stem to eye...
  13. Feb 7, 2012 at 10:53 PM
    TACWUT
    TACWUT Well-Known Member
    San Diego
    12 prerunner DC
    Flowmaster turndown, 5100 up front/5150 rear, maxtrac spindles, 2" tuff country add a leaf+TSB.
    You can get longer ones too depending on tour leaf pack application.
    You have to get a converter pack, if your refering to the 5150 shocks for example. They're like 20 bucks and are super easy to convert.
  14. Feb 8, 2012 at 5:36 PM
    Peter559
    cool, i will look into that... thanks!
