bilstiens with spacer lift
Discussion in 'Suspension' started by shawnresa, May 26, 2010.
  1. May 26, 2010 at 8:27 PM
    shawnresa
    shawnresa [OP] Member
    shawn
    jashua tx
    2009 4x4 prerunner
    3" lift 285/75/16 black procomp wheels
    i have a 3" top mount spacer on a 2009 4x4, tires are 285/75/16 with procomp wheels and rub a little i can live with but im going to buy some 5100s and want to know if i can combine the 2 or will it rub even wors with just the 5100s set at 2.5 what to do
  2. May 26, 2010 at 9:59 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    It depends on where it rubs. I'm guessing it would rub worse if you drop it back down .5".
    Skip combining the 3"spacer on the 5100's.
    Probably have to just trim the area(s) that it rubs.
  3. May 27, 2010 at 1:18 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    u can run the 5100's set at 0" w/ the 3" spacer....or run the 5100s at 2.5" and ditch the spacer, but neither will get u to not rub. gonna need to trim. the 5100s @ 0" w/ the spacer should at least ride better than the stock shocks w/ the spacer
  4. May 27, 2010 at 3:53 AM
    shawnresa
    shawn
    jashua tx
    2009 4x4 prerunner
    Ya the only place it rubs is the body mount I was thinking of triming that any ways I hope it drives better after the new shocks cuz now u fill every little bump in the stering wheel and I can't stand it I bought the light racing ucas thanking it would help and it didn't so we will see
  5. May 27, 2010 at 6:50 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    If I'm not mistaken those are 33"s so I bet you hes pretty close.
  6. May 27, 2010 at 10:12 AM
    jhodge83
    SC
    17 XLT Sport
    yep...i was until i got a good alignment that moved my wheel more forward
  7. May 27, 2010 at 3:38 PM
    shawnresa
    shawn
    jashua tx
    2009 4x4 prerunner
    It mostly rubs when backing up but not to bad and the tire come out to like a 32" so what would be a better ride billys at 2.5 or 0 and spacers
  8. May 31, 2010 at 12:03 PM
    Gonzo714
    Gonzo714 Member
    Jeff
    Anaheim
    05 pre-runner
    I have 2" spacers on my 05' PreRunner. I just got 285/75/16 put on and they rubbed the same way stated above. Just shave in small areas till no more rubbing. Worked for me.
    Now a question about 5100's and spacers. Should I leave the 2" spacers and set the 5100's to stock or remove the spacers and set the 5100's to 2.5"? I want to do whatever will be smoothest. What does everybody think? Anyone have personal experience with this???
    Thanks
    Cheers
