Binding/Metallic sound from front end while turning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mhshark, Jul 8, 2018.
  1. Jul 8, 2018 at 7:55 PM
    mhshark
    mhshark [OP] Well-Known Member
    Bend, Or
    Hey guys,
    I was driving on a windy road today and when turning somewhat sharp (25 mph “recommended” turn, going maybe 30-35mph) the front end seemed to bind up. The wheel would pull the other way somewhat and the traction control light would come on. A metallic type of sound also accompanied it.
    Any idea what this could be? Truck is lifted but only 2”. 4x4 was not engaged. When I went very slow through the turns it was ok but when going into them somewhat fast (not anything crazy at all, I’m not a fast driver) it would happen; happened 3 times in total.
    Any help is appreciated!
  2. Jul 8, 2018 at 7:57 PM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    May be ur trac control kicking in
  3. Jul 8, 2018 at 8:02 PM
    mhshark
    Bend, Or
    Would it really kick in going that speed? I drive this truck pretty lax I can only imagine what it does for more aggressive drivers!
  4. Jul 8, 2018 at 8:03 PM
    Jason TRD OR
    It's always kicking in pretty agressively when I'm out drifting trails in the desert so I just turn half way off by tapping the button once
  5. Jul 8, 2018 at 8:14 PM
    strktly_bodysurf
    strktly_bodysurf Well-Known Member
    Agreed with above. Shit won't let me burn out ever. :mad:
  6. Jul 9, 2018 at 8:38 AM
    mhshark
    Bend, Or
    Bumping this for any additional opinions. Totally could be traction control but I don’t feel like I was anywhere close to losing traction when it kicked on...
    thanks!
  7. Jul 9, 2018 at 9:37 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    2" lift? Maybe some high offset wheels/tires?
    Any slip indicators light up?
    Did you have VSC recalibrated when you had it aligned?
  8. Jul 9, 2018 at 9:42 AM
    mhshark
    Bend, Or
    Not really high offset, method roosts (even with the fender flare).
    Yes the traction control light kicks on
    Not sure if they recalibrated, never really knew that was a thing!
  9. Jul 9, 2018 at 9:47 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    There was a guy on here a while back where the 4x4 actuator was broken. Dash said 4x4 wasn't engaged, but it was. Do you think it is possible it is in 4wd? Just tossing it out for suggestions.
  10. Jul 9, 2018 at 10:09 AM
    mhshark
    Bend, Or
    Thanks for the suggestion. I don’t think it is honestly, I don’t get any binding at low speed right turns like I would if it was in 4x4. Just mid-speed somewhat right turns. Going fast enough to get a little body roll but still nowhere fast enough for any traction issues
