Bird Droppings! How do you get rid of the stains/outlines!?
Discussion in 'Detailing' started by TRDTaco808, Dec 9, 2009.
  1. Dec 9, 2009 at 1:56 PM
    TRDTaco808
    TRDTaco808 [OP] Member
    Pearl City, Hawaii
    2010 SR5 TRD Sport
    damn, first full day of owning the truck and already got blessed! two drops of bird droppings on the hood and two on the top ... wiped off easy but you can see at an angle the outline of the bird droppings!!!! is there a fast and safe way to remove the outlines? i tried to wax it out but not really working. ive got the Xzilon treatment from the dealer too?!!?!! any help ... thanks
  2. Dec 9, 2009 at 1:59 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Get some ScratchX 2.0 and rub it out with a microfiber towel.
  3. Dec 9, 2009 at 1:59 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    Quit looking at your truck from that angle.
  4. Dec 9, 2009 at 2:01 PM
    IndigoTaco
    IndigoTaco Well-Known Member
    07 Access Cab Sport 4x4
    You should take a dump on the hood to offset the bird shit. But really, detail spray.
  5. Dec 9, 2009 at 2:03 PM
    cbcs1987
    cbcs1987 Redneck from the hills
    Cody
    East Tennessee
    2007 Tacoma 4wd access cab
    6" Fabtech coilover lift. 35/12.50/17 Mickey Thompson MTZ, 17x9 ProComp 1089 wheels painted black, UWS black lowprofile toolbox, husky liners, tacoma bed mat, bed lights, Premier stereo, Cobra 19 cb, firestik 3' antenna.
    Mcguiars (spelling?) step one paint cleaner in a maroon bottle. Gets every thing out except dents!
  6. Dec 9, 2009 at 2:05 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    If I have bird droppings on my truck I use a microfiber towell with hot water to get it off. Keep your truck waxed. It will help prevent that crap from sticking.
  7. Dec 9, 2009 at 2:18 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Agreed. The Meguires detail spray works like a champ.
    Just don't let it stew for too long before you clean it off.
  8. Dec 9, 2009 at 2:19 PM
    WNYTACOMA
    Clarence, New York
    The new stuff in the black bottle gets the dents out too...
  9. Dec 9, 2009 at 5:36 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    Bird poop etches the paint. Basically, it leaves its imprint on the clear coat. Once it is washed away, you see the damage on the clear coat. Hence the outline. Just like a scratch, you will need to remove some clear coat in that area to remove the outline. ScrtachX 2.0 is the best, easiest to find product that will work. Deep Crystal Paint cleaner was a good product, it is disco'ed now so it might be hard to find. The paint cleaner was more of a last step product before you wax. It was designed to give a 'clean slate' so to speak before wax is applied.
    Get some ScratchX 2.0 and a pack of the orange microfibers at target. Keep those in your truck. Never know when you need a mark taken out. FYI, have some wax handy after you use the polish as the polish will take away any protection you have on you paint.
  10. Dec 10, 2009 at 8:41 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    Bird poop is acidic, so it basically eats paint. The depth of the etch will determine whether or not its removable, or should I say, at what cost.
    I have bird poop outlines on my hood (from the previous owner) and they will not come out; they are too deep.
    Scratch-X is an OK product, but contains fillers and uses diminishing abrasives. Use a high-quality micro-abrasive polish, like the Meguiar's M105/M205 combo. Unfortunately, they're not available in small amounts.
    Follow up with wax to protect the spot.
    Don't go too crazy trying to get rid of the etching. If it's deep, you may end up having to take too much clearcoat off to get rid of them and you'll end up with a bigger problems.
    Prevention is the best medicine. Keep your paint well-waxed, and keep a Quick Detailer and microfiber in your truck and as soon as you see the 'offense', wipe it off. Don't worry about scratches at that point...better to put mild scratches in that can be easily buffed out later than to leave acid on your paint.
    Meguiar's Ultimate Quik Detailer is a good off the shelf product. CSI also makes a good Detailer, but I am out of stock on that right now.
  11. Dec 11, 2009 at 1:20 AM
    TRDTaco808
    Pearl City, Hawaii
    2010 SR5 TRD Sport
    yup, im taking all the advice ... already stocked microfiber towels, bottle water with soap mixed into it already, wax, polish clothes, ScratchX 2.0, sponge in my cargo compartments for that quick wipe off if i see any bird droppings ...
    thanks peeps!
  12. Dec 11, 2009 at 2:39 AM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    If that does'nt work, I use a product made by 3m called "finesse it". Its a finishing compound used in the final stage of rubbing out paint. Comes in a plain white bottle with a black and white label. Hard to find and very expensive, but most body shop supply stores carry it and it works well with an orbital, rotarybuffer, or by hand. It removes swirls and any blemishes left by heavier rubbing compounds or bad technique.
  13. Dec 11, 2009 at 2:41 AM
    swise
    swise TRIFECTA!!!
    ohio
    wow, dude - your as anal about it as I am!
  14. Dec 11, 2009 at 3:15 AM
    GotLift37
    GotLift37 Bangers Runner
    down south
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion
    igno1tus likes this.
