Birds in the glove box, squeaking noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by JShawFSU, May 30, 2019.
  1. May 30, 2019 at 10:21 AM
    JShawFSU
    JShawFSU [OP] Well-Known Member
    2001 XtraCab SR5 4WD 201k miles
    Nothing
    I have on again off again tweeting noise from my glove box. It literally sounds like a nest of birds is in there. I was told by the previous owner that it had something to do with the passenger airbag, and if disconnected it would go away. I thought I'd ask ya'll for advice prior to going in and messing around in there.
    Thanks,
    GQ7227 likes this.
  2. May 30, 2019 at 10:55 AM
    albert7991
    albert7991 Active Member
    Albert
    Vancouver WA
    99 Red Tacoma SR5 TRD Off Road 200K+
    Fabtech suspension 4.5" lift Rolling on 33s Gutted
    Have you tried checking for birds? Haha jkjk but i would take out the glove box and wait for the noise to come back. Try to isolate it. Might be a blend door motor for the evaporator acting up. When the noise comes does it go away on its own shortly after a key cycle or at random?
    Garwood likes this.
  3. May 30, 2019 at 11:10 AM
    JShawFSU
    Nothing
    It comes and goes at random. Some days it wont act up at all, while others it will tweet its lungs out. It isn't constant either or predictable at all either. does mulitple tweets to a few tweets, no tweets. It occurs all on random.
    Garwood and GQ7227 like this.
  4. May 30, 2019 at 11:16 AM
    1DVS-BSTD
    1DVS-BSTD is probably confused
    The Corn Is Pretty Good Here
    '03 TRD Off-Road, '22 Poverty Spec
    881's, Nitrochargers, Dakars, SR8's, Duratracs
    Sounds like it could be the infamous 1st gen dash squeak. Mine seems to do it at random as well. Some folks have had luck with wedging folded up paper or something similar between the windshield and the dash/A pillar. YMMV. Worth a try before you go disconnecting anything.
    GQ7227 likes this.
  5. May 30, 2019 at 11:17 AM
    albert7991
    Albert
    Vancouver WA
    If its a dash squeak can you attempt to play with the dash pulling pushing shaking etc with it and get it to duplicate?
  6. May 30, 2019 at 11:18 AM
    1DVS-BSTD
    Not sure. Just know that it's a complaint I've read about on here before. Mine seems to do it on cooler mornings. Don't notice it much later in the day. Haven't tried the paper wedge thing yet...I forget about it at the end of the day. :D
    skeezix and GQ7227 like this.
  7. May 30, 2019 at 11:20 AM
    1DVS-BSTD
    GQ7227 likes this.
  8. May 30, 2019 at 11:21 AM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    The dash squeak drives me crazy. Not to thread jack, but Does any one know a proper fix for that ? Also it sounds like to me your blower motor could have debris in it.
    GQ7227 likes this.
  9. May 30, 2019 at 11:23 AM
    JShawFSU
    Nothing
    No worries haha - we are all here to get a answer one way or another.
    GQ7227 likes this.
  10. May 30, 2019 at 11:25 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i have the chirpy noise as well but NO passenger airbag :notsure: its been there probably more than a decade closer to two
    its there in the winter, spring and summer
    i turn up the fan setting and seems to go away
  11. May 30, 2019 at 11:28 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Have you ever purchased something for your Yota and been like, "damn, I should have done that a long time ago"? I had an annoying dash rattle but didn't do it all the time. When it did do it, I could press on the dash where it meets the windshield (passenger side) and it would stop.
    I purchased some rubber seal strip and placed between the window and dash. Haven't heard a peep since.
    https://www.amazon.com/gp/product/B012NMCVFE/ref=ppx_yo_dt_b_asin_title_o04_s02?ie=UTF8&psc=1
    GQ7227 likes this.
  12. May 30, 2019 at 11:29 AM
    FreshOldTaco
    FreshOldTaco Well-Known Rider
    kevin
    2003 Tacoma
    I get an occasional squeak/rattle in the dash, rarely happens then stops on its own :notsure:
    GQ7227 likes this.
  13. May 30, 2019 at 11:31 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    does this noise NOT happen when fan is off?
    Garwood and Running Board Man like this.
  14. May 30, 2019 at 11:34 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    does/did yours ever squeak with just turning the fan on?
    A/C or Heat? mine has it bad both ways sometimes
    other times now hahah
  15. May 30, 2019 at 11:36 AM
    jammer
    Ben
    Bentonville, AR
  16. May 30, 2019 at 11:36 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    how about your SR5 seats?
    squeaky???
    i gots me one dont know what to do, gotta git er fixed
  17. May 30, 2019 at 11:36 AM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    I have a dash squeak, but only when driving. and its clear that its a dash squeak. I think you may actually have birds in there lol
    GQ7227 and Running Board Man like this.
  18. May 30, 2019 at 11:40 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i have multiple squeaks drives me crazy! i need to take better care of it
    Running Board Man likes this.
  19. May 30, 2019 at 11:40 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    how the hale does a rod get rusty inside my seat right under my left armpit!!! to my shoulder area
  20. May 30, 2019 at 11:42 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    well i am not about to go that far :crapstorm:
