Bison Offroad alignment Stop Cams -- giveaway
Discussion in 'Buy / Sell / Trade' started by Bison Offroad, Aug 27, 2020.
  1. Sep 10, 2020 at 2:56 PM
    #101
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Yes.
    fatfurious2[QUOTED] likes this.
  2. Sep 11, 2020 at 3:35 PM
    #102
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Well keep innovating. The Tacoma market is huge although very saturated, which is what makes new parts such as these cams so refreshing to see. Also thank you for offering them at a reasonable price. OEM cam bolts are too pricy.
    TacoPandaTRD and Biscuits like this.
  3. Sep 11, 2020 at 3:54 PM
    #103
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    McMaster has a smallish variety of sizes - any word on 1st gens?
    Godzilla619 likes this.
  4. Sep 11, 2020 at 4:15 PM
    #104
    FarmBoyTaco
    FarmBoyTaco Work Hard, Stay Humble
    Josh
    California
    '12 TRD Off-Road DCSB MGM
    Just got bolts (and sleeves) in the mail! Will be installing on the 23rd with the rest of my suspension parts!
    fatfurious2 and Biscuits like this.
  5. Sep 11, 2020 at 9:29 PM
    #105
    Bison Offroad
    Bison Offroad [OP] Active Member
    Cord
    Level and Lift Kit manufacturer
    UPDATE: the sleeve material from McMaster Carr DID NOT show up today. However, I did some major searching and FOUND some sleeve material with the right dimensions. This is for the TC-1503 2016-2020 models. I have to admit--when you see the "sleeve" you're gonna laugh. It's thin, but it does the job of centering the bolt. There are other suppliers of replacement camber kits that grind their bolts in the shape of a "D" in order to lock in the eccentrics. We don't have that problem because the flats are built into our cams, so the sleeve is less important for our application. And the bolt is stronger. In other words you could probably even get away not using the sleeve. But it's there.
    Here's a little "show and tell."
    IMG_20200213_150856.jpg So here are some GM Chromoly UCA's that I make that include a uniball stud mount. That part is usually enclosed but the cap isn't on. You can see the zerk fittings, which is the reason for the picture. Use SUPERLUBE with urethane bushings, and don't squeeze in too much or bad things will happen. Yes, I have Chromoly Taco UCA's coming out, prolly this year. Chromoly is generally twice the strength of DOM, so it's worth using.
    IMG_20200827_134141_01.jpg These are offset upright (hub) bushings. They press in top and bottom in order to increase the negative camber. Not applicable to Tacos.
    IMG_20200826_135545_01.jpg This is a UHMW bushing, also not applicable for Tacos unless you're going for NVH. The neat thing about this material is that it's self-lubricating. Most people use Delrin. This is better, IMO.
    IMG_20200826_135511_01.jpg Here's another bushing I make. The center is a uniball. The reason is to prevent any type of binding during the suspension sweep. Again, not Taco related but I thought you might be interested.
    We make our own urethane bushings in house as well as the crush sleeves that go in the center, and it wouldn't be a big deal to make OEM replacements for worn out bushings. But is seems like most people switch over to stronger aftermarket control arms. Beyond that, the "next step" for a-arms would be running two crush sleeves, one inside the other, for a smooth rotating surface. But as you can see from the above pictures, you can quickly get into a case of "creeping elegance" where you add every possible feature to a product and all you get is expense and complexity. Most of the time simple is better.
  6. Sep 11, 2020 at 9:39 PM
    #106
    Bison Offroad
    Cord
    The R&D is done for the 1995 to 2004 1st Gen. Is there interest in this model?
  7. Sep 11, 2020 at 10:10 PM
    #107
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Let me know if you need another truck to test them on - very interested
  8. Sep 12, 2020 at 5:18 AM
    #108
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    some urethane or UHMW replacement bushings for the 3rd gen lower control arms would be banging.
    no one makes them yet. Whiteline says they are in the works but no timeline as to when they will be available.
    On the lowers - The 3rd gen rear bushings are larger diameter than the 2nd gen. The front bushings are the same size for both gens.
    mcharfauros, Biscuits and su.b.rat like this.
  9. Sep 15, 2020 at 7:02 PM
    #109
    Bison Offroad
    Cord
    I got a PM tonight that said in essence, "Really? These plastic sleeves are what I waited for?" Yep, that's it. My reply:
    Yes, believe it or not that's what was missing. I have trucks running without them and have not had problems, and frankly future kits will have steel inserts. To make you feel better, SPC Alignment uses plastic inserts in their kits. I think it's more because they have a "D" shaped bolt and ours is clearly fully round. Mark your current bolt first and grease it all up. The threads are supposed to stay dry. The bolts are 14mm (146ft/lb torque) and 16mm (224ft/lb)10.9 grade metric, and add 10lbs torque to each to account for the crush nut.
    Biscuits likes this.
  10. Sep 15, 2020 at 7:04 PM
    #110
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I think I got copper sleeves.. :anonymous:
  11. Sep 15, 2020 at 7:04 PM
    #111
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Special edition
  12. Sep 15, 2020 at 7:08 PM
    #112
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    2nd gens have a smaller diameter bushing, that’s why. The third gens are larger rear diameter, but the fronts bolts are the same as the 2nd gen.
    I had another small issue with my order but Cord was quick to respond to my email and taking care of it. Customer service couldn’t be better IMO.
  13. Sep 15, 2020 at 7:12 PM
    #113
    fatfurious2
    David
    Ashburn, VA
    ah ok. Makes sense. I didnt see who was responding.
    Do copper and steel not mesh well together? side note for myself.. (and because I have TC LCAs)
  14. Sep 15, 2020 at 7:20 PM
    #114
    Bison Offroad
    Cord
    Chromated steel is better, but greased up copper should be fine.
    fatfurious2[QUOTED] and Biscuits like this.
  15. Sep 16, 2020 at 5:52 AM
    #115
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    Bison Offroad,
    Thank you for the shirt and sleeves! Right size too!
    Biscuits, mcharfauros and Drainbung like this.
  16. Sep 16, 2020 at 5:56 AM
    #116
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    You mean to tell me, the shirt comes with sleeves :cookiemonster:
  17. Sep 16, 2020 at 7:49 AM
    #117
    mcharfauros
    mcharfauros IG: mcharfauros
    MO
    2017 Black TRD OR DC
    Dumb Truck Thangs
    :rofl:
  18. Sep 16, 2020 at 2:58 PM
    #118
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You going to make these for 1st gen trucks too?
  19. Sep 16, 2020 at 2:59 PM
    #119
    Blackdawg
    Monte
    Wyoming/St. Louis
    Just saw this.
    In short.
    Yes there is.
  20. Sep 17, 2020 at 4:09 PM
    #120
    oakcity
    oakcity Well-Known Member
    Jesse
    Raleigh, North Carolina
    2009 Grey Tacoma AC 4x4
    Money Pit
    Heres my basic Betty work in progress lol
