bit by mod bug
Discussion in '1st Gen. Tacomas (1995-2004)' started by higherlux, Jan 19, 2009.
  1. Jan 19, 2009 at 3:20 PM
    higherlux
    higherlux [OP] Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    last week i installed a small lift
    today i did the differental breather relocation mod
    and now i wanna do a deck plate mod
    so my question is where can i get a deck plate??
    i have a 98 2.7 tacoma 4wd
  2. Jan 19, 2009 at 3:22 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you'll need a 4 inch deckplate.....and online, you can get one from overtons.com, or if you have a local boating supply place...they should have them.
    the deckplate mod is awesome man!!:D
  3. Jan 19, 2009 at 3:41 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    would a place that sells boats and atvs and utvs have them ?
    and i have a marine store thats like 2 miles away from my house but im not shure if its out of buisness or not?
  4. Jan 19, 2009 at 3:51 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    what does the deckplate do?
  5. Jan 19, 2009 at 4:01 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    you cut a 3 inch hole in your air box and put a deck plate in and when you remove it BOOM extra horses
  6. Jan 19, 2009 at 4:06 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    the inlet "horn" on the stock air cleaner box is pretty small. a deckplate (when open) mod will allow a lot more air in quickly. some say it gives you more ponies than a 300 dollar CAI does.
    you can follow up the deckplate mod with the intake silencer mod if you want a growl when you put your foot in it.
  7. Jan 19, 2009 at 4:23 PM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    ahh... thanks guys... :thumbsup:
  8. Jan 19, 2009 at 4:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i may have misspoken when i said "4inch deckplate".........it may or may not fit the 2.7 motor. a 3 inch(if they make them) may fit it........4 inch may,but im honestly not totally sure.
  9. Jan 19, 2009 at 6:13 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    ill get out tomarro and measure to see
  10. Jan 19, 2009 at 6:20 PM
    carolinyens
    carolinyens Creedmoor Connections
    Durham, NC
    08 X-Runner
    TRD CAI, TRD SS, Toyota All Weather Mats, Eagle Eye Halos, NST Crankshaft Pulley, ScanGauge II, TRD Shiftball, TRD SeatCovers, WeatherTech Vent Visors, 20% tint, DTLT's and NST pulley combo.
    I know its offtopic but I helped put in an irrigation system in Mr.Overton's house before I moved back to the homefront. This dude has his own lake and golf course and grounds crew on his land. Ridiculous income and the worst part is he's not that smart but he is a nice guy.
  11. Jan 19, 2009 at 8:34 PM
    2004Taco
    2004Taco Well-Known Member
    Long Beach,CA
    04 PreRunner SR5 Trd
    Magnaflow and Deckplate Mod Billet grille
  12. Jan 19, 2009 at 9:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    A 4" will fit fine on the 2.7. :)
  13. Jan 19, 2009 at 9:34 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    a lot of people have adopted the deckplate mod (including me) to a non supercharged 3.4 (and some 2.7l) engines
    the dyno tests done with it were on a superchaged 4runner and it consistently got better #s than supercharged with a CAI
    when you can spend $10 instead of $300...its worth a shot
    a lot of people close them when they go thru water or if its raining etc etc
    i leave mine open all the time...ive never had an issue...once i had a spot of mud get under the filter...but it was about a quarter sized spot and you could tell it had just barely squeezed under
  14. Jan 19, 2009 at 9:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The dyno runs I have done with it, were all on NA engines and showed similar gains. :)
  15. Jan 19, 2009 at 9:37 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    i would assume as such...but the only posted results ive ever seen were on a supercharged V6
  16. Jan 20, 2009 at 7:09 AM
    HerNameIsLucy
    RIP Lucy.
    The writeup at TRDOffroad says the biggest that'll fit on a 4 banger is a 3 incher:
    Materials and items needed:
    - 3-5 inch deckplate (3" is as big as you can fit on a 4-cyl)
    - 3/4 inch long pan head screws
    - matching nuts, (nylocks prefered) and washers
    - 1 bottle of black RTV "sensor safe" silicone
    I've never seen under the hood of a 4 so smart money would take Chris' word for it. ;)
  17. Jan 20, 2009 at 11:52 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    a 4 inch will fit but the windsheild washer fluid filler will be in the way
    but is it possible to put it on the side???
    it looks like threr would be enought room
  18. Jan 20, 2009 at 2:06 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can still install the deckplate in front.........washer filler wont have any real negative affects....maybe a bit tighter to get the cap screwed in.....but you'll be leaving it off for the biggest majority of the time.
  19. Jan 20, 2009 at 3:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2. Take the air box out to do the install. The washer filler neck can be moved out of the way enough to put the deck plate on if needed.
  20. Jan 20, 2009 at 3:21 PM
    Bs 02 Taco
    Bs 02 Taco Well-Known Member
    Amelia, Ohio
    02 Tacoma 4x4 regular cab 5 speed
    Swiss cap Deckplate Stupid door chime Synthetics AFE pro dry JVC Ipod compatible head unit Vanilla air freshener :) 25%tint
    A 4" will fit.
    That what I put in my 2002 2.7
    It gets a little louder in full throttle
    The deckplate barely fits so measure 3 times and cut once :)
