Bit the bullet on URD Spec headers
Discussion in 'Performance and Tuning' started by FreeRanger, Nov 30, 2014.
  1. Nov 30, 2014 at 4:08 PM
    FreeRanger
    FreeRanger [OP] Well-Known Member
    Texas
    11 tacoma
    URD TCAI, URD MAF CAL, URD SPEC Headers, Billy 5100's at 2.5", 33's on 18's
    Just purchased some URD Headers on the black friday sale so I figured now was the best time if any.
    Wanting to know if anyone has had them for a while on a N/A engine?
    Whats the pros and cons?
  2. Dec 2, 2014 at 5:49 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Installation is the only "con", to me.
  3. Dec 2, 2014 at 7:33 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I'm still on the fence about mine..
  4. Dec 2, 2014 at 10:56 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    waiting for outcome
  5. Dec 2, 2014 at 1:56 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    x2
  6. Dec 3, 2014 at 7:35 AM
    FreeRanger
    Texas
    11 tacoma
    Still waiting on them to be sent, said they were being made, but thats what I heard that installing was a PITA but im pretty mechanically inclined so hopefully that helps out some. I will post results and some install write up.
  7. Dec 3, 2014 at 7:51 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    I want to see if they improve performance on the butt dyno
  8. Dec 3, 2014 at 8:01 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    On both heads, we removed the top and bottom rear most studs. As well as on the the steering coupling. That part was mandatory for clearance.
    Lucario Runner said that he immediately felt a pick up in lower end power.
  9. Dec 3, 2014 at 8:21 AM
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    So my low end would improve then? My DTLT headers killed my low end. But I have a nice top end.
  10. Dec 3, 2014 at 8:46 AM
    FreeRanger
    Texas
    11 tacoma
    Are they a tighter fit in the 4runner compared to the tacoma? and Im keeping my exhaust stock so i dont open it up too much so hopefully that helps with not loosing the low end power to and the butt dyno is the only dyno that matters! ;)
  11. Dec 3, 2014 at 9:06 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not sure. I've only installed them on a 4Runner.
  12. Dec 3, 2014 at 9:44 AM
    FreeRanger
    Texas
    11 tacoma
    I thought about taking it somewhere to get it done, but couldn't justify paying for something I can do. Time will be my only problem. On lucarios 4runner did he have the y-pipe already done before he put the headers on?
  13. Dec 3, 2014 at 10:07 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    the top end definitely seemed to increase.. at least on my application. although.. I didnt have JUST the headers. the exhaust was fully done at the same time.. so hard to determine what modification did what..
  14. Dec 3, 2014 at 10:14 AM
    FreeRanger
    Texas
    11 tacoma
    Were you booster at the time?
  15. Dec 3, 2014 at 10:16 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I was..
    I went from boosted + stock exhaust
    to boosted + Spec U headers, custom Y pipe, and 3" exhaust.
  16. Dec 3, 2014 at 10:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I bought his second gen DTLT's, from him, and we swapped in the Spec-U headers. Yes he had the URD Y-pipe already. Still has his stock catback.
  17. Dec 3, 2014 at 10:37 AM
    FreeRanger
    Texas
    11 tacoma
    I almost bought a supercharger, wish I would have now but at least all this can still benifit it if I ever decide to. How would you compair the DTLTs to the URD headers? i was going to get the DTLTs but with the black friday sale the URDs ended up being the same price.
  18. Dec 3, 2014 at 10:39 AM
    FreeRanger
    Texas
    11 tacoma
    I have 100,000 miles on my truck so I imagine the bolts will be fairly hard to get off lol
  19. Dec 3, 2014 at 10:40 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    both are long tubes.. the URD headers i think give a more consistent power band IIRC.
    correct me if I'm wrong.
  20. Dec 3, 2014 at 10:47 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If you can find bolts, of a proper grade. www.Dezod.com carries ARP studs as a replacement. They are especially helpful for those is salty/snowy areas, as they won't rust like the factory ones. Have to chase the threads though, as they are a very tight tolerance. Versus the '03-'04 1GR heads.
