Bit the bullet on URD Spec headers
Discussion in 'Performance and Tuning' started by FreeRanger, Nov 30, 2014.
  1. Dec 3, 2014 at 10:51 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Both are long tubes, but the URD version is all equal length. So no opposing exhaust events. Should equate to higher torque. There is actually a dyno on XRU, of just a long tube header mod. :thumbsup:
    Which can be compared to Doug Thorley's dyno.
  2. Dec 3, 2014 at 11:07 AM
    FreeRanger
    FreeRanger [OP] Well-Known Member
    Texas
    11 tacoma
    URD TCAI, URD MAF CAL, URD SPEC Headers, Billy 5100's at 2.5", 33's on 18's
    Ok sweet thanks man! Hopefully my bolts will be ok I live by Sa Antonio so not to much corrosion down here but you never know. The gaskets that are on the original manifolds are to be resused with the urd headers correct?
  3. Dec 3, 2014 at 11:18 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    awaiting the updates :D
  4. Dec 3, 2014 at 12:17 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Correct.
    PM Lucario Runner. He lives in SA as well.
  5. Dec 3, 2014 at 12:24 PM
    FreeRanger
    Texas
    11 tacoma
    Maybe we can have a friendly race when i get them put on and tuned in ;)
  6. Dec 11, 2014 at 9:35 AM
    FreeRanger
    Texas
    11 tacoma
    They will be arriving tomorrow! Hopefully I'll have them on Sunday or Monday and I'll post some results. Quick question the long tubes lean out my AFR more right?
  7. Dec 12, 2014 at 6:00 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    In closed loop, no, the af sensor that you install into the headers will still function as normal. In open loop, probably, but how much, and is it enough to matter, that I don't know. Ask Gadget/URD. He may recommend a maf cali, assuming he has a map for those headers too.
  8. Dec 12, 2014 at 9:02 AM
    FreeRanger
    Texas
    11 tacoma
    I have the Maf Cal with the base tune and URD TCAI but I haven't put the intakes tune on it yet. I was holding off because I figured the headers would lean it out and didn't want to go to lean and not be able to monitor the AFR through the cats sensors. I don't think he has a tune for the headers though cause when I asked he just sent me the tune for the intake.
  9. Dec 12, 2014 at 9:22 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    The af sensor is further upstream and still should be installed in the headers, either in the collector, or on one of the header tubes. This will control closed loop. The cat sensors are located further downstream and are not used, they are replaced with the sensor eliminator. These are not used to set injector pulse, but to monitor cat efficiency, if I remember all this correctly
  10. Dec 12, 2014 at 10:03 AM
    FreeRanger
    Texas
    11 tacoma
    Ahh ok gotcha! See I thought the simulators were for AFR sensors. So if I were to tune it and It were to go to lean which I doubt it would, but to be on the safe side that sensor would still throw a lean code?
  11. Dec 12, 2014 at 10:17 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    my URD headers didnt lean out anything according to my AFR gauge..
  12. Dec 12, 2014 at 10:55 AM
    FreeRanger
    Texas
    11 tacoma
    Ok good to know just making sure, and like Lurkin stated the AFR sensors aren't being replaced with the simulators just the rear cat sensors?
  13. Dec 12, 2014 at 10:58 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    exactly. youll be using the o2 sims since youll be losing a set of your cats with the installation of the headers.
  14. Dec 12, 2014 at 11:48 AM
    FreeRanger
    Texas
    11 tacoma
    Ok got it thanks! Hey moose did you install your headers yourself or take it somewhere?
  15. Dec 12, 2014 at 11:54 AM
    #35
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Took it in somewhere. Had the exhaust shop that did my exhaust slap em on at the same time.
  16. Dec 12, 2014 at 12:01 PM
    #36
    FreeRanger
    Texas
    11 tacoma
    Ahhh yes I forgot terrible memory lol How much do you think they would charged to just do the headers? Couldn't be too much considering there is no welding just Bolt-on
  17. Dec 12, 2014 at 12:18 PM
    #37
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    whatever the shop rate is.. maybe around a couple hundred, if that?
  18. Dec 12, 2014 at 2:23 PM
    #38
    FreeRanger
    Texas
    11 tacoma
    I'll probably just end up doing them myself on Sunday if I can find the time.
  19. Dec 12, 2014 at 2:26 PM
    #39
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I would have done the same, but since it was going to be there all day for the exhaust anyways.. plus.. i needed them to weld in the AFR sensor.
  20. Dec 12, 2014 at 2:37 PM
    #40
    Traviste
    Traviste Now with more woopow
    Travis
    Georgia
    2014 DCSB Locked 4x4 Mid-Travel
    F:King 2.5 coilover resi ext 700#coils R:King 2.5 ext allpro expos
