Bits of foam blowing through air vents?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ToyotaBanjo, Nov 14, 2017.
  1. Nov 14, 2017 at 5:06 PM
    ToyotaBanjo
    ToyotaBanjo [OP] Well-Known Member
    Outer banks
    2006 DC 4x4 Sport
    None
    i have a 2004 double cab...had to have AC work done (replaced evaporator). I have noticed bits of the dark gray foam that comes out of the registers when the air or fan is on.....assuming it may be due to disturbance when working on it or just 14 year old lining that has dry rotted. Any ideas on how to alleviate or get it out?
  2. Nov 14, 2017 at 5:49 PM
    Glamisman
    Glamisman Well-Known Member
    not much you can do at this point. The factory evap is really encased by foam and I cant see the tech just saying the hell with it and not cleaning it out before reassembly. The only other place foam can come from is the crossover tube immediatly behind the glove box. There is a ring of foam on both ends. If you drop the glove box to its stop, then push in on both sides of the glove box at the door/dash the door will drop more. Then you can see the tube. A quick wiggle and you can tell if there is any foam left... she might wistle at high fan speeds if the foam is gone.
  3. Nov 15, 2017 at 1:40 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    The outer edges of the outer vent doors in the upper dash have a thin layer of black/gray foam to aid in keeping a air tight seal when you close those vents. They've recently started to deteriorate on my 04.
  4. Nov 15, 2017 at 1:53 PM
    GrnXnham
    GrnXnham Member
    Tacoma, WA
    2015 PreRunner Auto 4-Banger
    I had this happen.
    I was able to fish the foam out from behind each vent using a pair of long thin tweezers.
  5. Nov 15, 2017 at 3:27 PM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    My vents have the same issue. Every now and then i find a piece that blew through. The day i find a piece of that shit in my drink i'll hire a thai hooker to suck that shit out.
    kumurick and tcjacado like this.
  6. Nov 15, 2017 at 3:49 PM
    voodootruckers
    voodootruckers Well-Known Member
    Some funny shit right there.
  7. Nov 15, 2017 at 4:06 PM
    tony2018
    tony2018 Well-Known Member
    I hope they replace the old deteriorated foam with something new...
  8. Nov 15, 2017 at 5:45 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    It's part of the vent seal. Happens to me too on my '98. 20 year old foam doesn't fare well.
  9. Nov 15, 2017 at 6:07 PM
    Taco302
    Greenbow, Alabama
    I'm thinkin a line of silocone should seal it up...nvm..then you couldn't angle the vent.
  10. Nov 15, 2017 at 6:10 PM
    Floridagulfcoasttaco
    Floridagulfcoasttaco Well-Known Member
    Noah
    1999 Tacoma extended cab prerunner
    I’ve been having brown chunks of foam type stuff that breaks apart and blows everywhere ever since I bought my 99 extra cab 3 years ago. Drives me nuts:frusty:
  11. Nov 15, 2017 at 6:13 PM
    Taco302
    Greenbow, Alabama
    Brown chunks that blow everywhere...can we park our trucks in separate lots?
    tcjacado likes this.
  12. Nov 15, 2017 at 6:54 PM
    Noah
    It all started after one of those Thai hookers you speak of worked on my truck :rofl:
    kumurick likes this.
  13. Nov 15, 2017 at 7:02 PM
    Taco302
    Greenbow, Alabama
    Oh dear sweet baby jesus...help us!!
  14. Jul 15, 2018 at 11:54 PM
    kumurick
    kumurick Member
    Richard
    2008 White Tacoma Base Model
    None
    I have a 2008 that I bought a few months ago (May, 2018) with 88,000 miles. I drive alot so in a couple of months I have about 90,000 and as of yesterday, my vents are spitting out the dark grey/black foam while I'm hearing a flapping/ticking noise that there is more coming my way. The only problem is that I haven't been able to find any diagram or explanation of where it's coming from.
    I want to fix the problem (Noise & emitted foam) but I also want to replace what is being blown out since I'm sure it serves a purpose of filtering, sealing or ?.......
    .....Can we revive this thread.....?.......What else do we know?................
