Bixenon HID's
Discussion in 'Lighting' started by banzaikid1, Jan 1, 2009.
  1. Jan 1, 2009 at 2:26 AM
    banzaikid1
    banzaikid1 [OP] Well-Known Member
    I was just wondering if I have to connect the line with the fuse directly to the positive side of the battery or if I can put it to any positive line? Also I was wondering if anyone has any pics of there install showing where they put all there wires and ballast. I searched and found some pictures but couldn't find any that really showed full detail of where everything goes.
    Thanks
    Brad
  2. Jan 1, 2009 at 9:23 PM
    banzaikid1
    Ok I managed to hook up the headlights and they seem to be working ok. I didn't hook it up directly to the battery I just put it to another hot line. I did have a problem with the fog lights though I can't get them to work I switched the ballasts but they still don't work. So I just put back my stocks and the stocks work so I think there is a problem with the bulbs or the ballast. Also are the ballast supposed to be making a buzzing noise.
    Thanks
    Brad
  3. Jan 4, 2009 at 10:18 AM
    GotLift37
    GotLift37 Bangers Runner
    down south
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion
    The ballasts will make a buzzing noise till their are fully warmed up. Also some HID's you buy. They will have reversed polarity. All you have to do is switch out the wires on the connection the red/black usually
  4. Jan 15, 2009 at 11:12 PM
    dcasillas
    dcasillas Well-Known Member
    san diego
    2004 prerunner quadcab
    donhoe coilovers,total chaos arms
    how did u hook to power
  5. Jan 16, 2009 at 11:13 AM
    banzaikid1
    There hook up through a harnes and I got power from the fuse box
