bjmoose asks "why is that damn bench seat so uncomfortable?"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bjmoose, Apr 6, 2011.
  1. Apr 6, 2011 at 12:26 AM
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    On the test drive, of course, all is well. But as the miles add up and longer trips are taken, an inescapable conclusion comes out. "This bench seat sucks. It hurts!"
    I had to find out why. First part is pretty obvious - no lower back support. It hunches you over like that famous dude who hung out in that Paris cathedral.
    But why does my butt hurt? I kept feeling down into the seat. There's *something* hard and sharp in there, set a little ways into the foam - and it's NOT the wire support grid on the bottom holding the seat up. Going to Moab for a week-long road trip over Easter break. A week in the saddle! Something has to be done! I was emboldened by this thread, describing removal and reinstall of the seats to put on spiffy new leather seatcovers:
    http://www.tacomaworld.com/forum/technical-chat/89333-diy-leather-interior.html
    But, before we can remove the seat, we're immediately thwarted by the simplest of questions: "How do I disconnect the center seatbelt?" 'Google Search' to the rescue, I found this thread:
    http://www.tacomaworld.com/forum/2n...ing-middle-seatbelt-bench-seat.html#post95099
    by googling
    disconnect center seat belt bench seat site:tacomaworld.com
    So, on the newer Tacomas you have to pop open the buckle and cut a slot to gain access to the hidden release button. I cut a little access slot with an Xacto knife, and now I can remove it whenever I want by sticking a key in there.
    Once that's done, check out the wiring. First - please disconnect the negative battery terminal! You don't want the airbag exploding while you're working on it!! Now, the newer seats all have airbags built in, as well as seat-belt detectors, and the new bench seat has a passenger weight detector, so when my 8 year old daughter sits in the passenger seat - it automatically disables the air-bag on the passenger side, but it operates normally when a heavier adult sits there. Slide the seat all the way back, locate the five or six wiring harness connectors, and disconnect them, without folding, spindling, or mutilating them. (not shown)
    Remove the four bolts holding the seat, and the two bolts holding the seat belts. You might be tempted to leave them in the cab, but the're wired into the seat wiring harness and it's just easier to unbolt them and bring them with. (not shown)
    Once the seat is out, set it on a blanket or something so it won't get all filthy as you turn it every which way on the ground while we're working on it, and remove the plastic side covers:
    ...and remove the two bolts on each side holding the seat back to the seat bottom. Careful, they're still wired together by those two airbag wires. We're leaving them in place.
    Take careful note of the seat cushion. See that "H" stitching and how it's set deeply into the seat? Doesn't that give it a racy looking contour? Don't you think that stitching says "expensive-custom-seat-not-a-cheap-bench-seat?" :rolleyes: Yeah, I don't either. But someone in Toyota had this bright idea....:mad:
    Flip the bottom over and disconnect all the seat cover attachment rails/clips. But we won't be able to remove the cover completely without unbolting the seat proper from the sliding rail/mount system, which looked to me like more trouble than it was worth. You may decide differently.
    Here's the bottom of the seat with all it's wiring and support springs. Disconnect the extra wire clips to get a little more room to work between the back and the seat bottom.
    Disconnect the seat cover at the seat belt openings. Mostly this involves removing hog rings - but there was one zip tie on there. When we reassemble, we're going to use zip ties.
    We can now strategically pull back corners and edges of the seat cover, except for the outside edges.
    And peel it back some more, and investigate what's in those custom contour grooves. What could it be?
    After a little work with needle nose pliers (a couple hog rings have to be removed)
    ...and now we now know EXACTLY what it is! Looks comfy, no? :eek:
    ...a little more work, and they are all removed:
    ...and the little wooden chopsticks that the hog rings were anchored to:
    OK, so we've solved the mystery of the seat cushion. Now onto those "Hunchback of Notre Dame" seatbacks. I got a couple "McCarty's Sacro-Ease Keri-Back" 14"x19" lumbar support seat backs to install. They're designed to strap onto the seat externally, but since we've got the thing out and apart, we can do a little better looking more permanent installation than that.
    Here's a link, but I bought mine locally. They're a little pricey, but many of you guys are buying Wet Okoles and other covers that cost even more coin than this. Anyhow, here's one source I found with google - haven't bought from them so I have no idea how good they are. http://www.healthyback.com/products/mccarty/mccartys-sacro-ease-keri-back-support/40
    Just sitting on the seatback, where we're going to install them
    All the straps we need to remove. Those plastic body clips poke well into the seat cushion, too.
    Destructively removing the body clips and straps with the biggest channel-locks in my toolbox:
    Soldering iron with upholstery tip:
    Exposing the back of the seatback, where we're going to want our lower ziptie attachment to come through the seat, so we can put it on the lower of the two smaller diameter bottom rods
    The hole in the seat fabric and cushion, made with the soldering iron, and the zip tie we're putting through it. This is the bottom of the support we're anchoring first.
    And the zip tie poked through and anchored on the other side. You're going to have to use your own careful judgement in tensioning these zip ties. Too loose and the seatbacks won't stay in position. Too tight, and you'll change the shape of the seatback itself, and not in a desirable way.
    KeriBack folded out of the way to reveal the two top mount holes we made with the soldering iron. We'll hold it in place with a total of three zipties. IMPORTANT NOTE - YOU MIGHT BE TEMPTED TO ZIPTIE THE OUTER (DOOR) SIDE OF THE KeriBack TO THE SEAT. I CONCLUDE THAT DOING SO MIGHT PUT A HOLE IN THE SIDE CURTAIN AIR BAG. USE YOUR OWN JUDGEMENT HERE, BUT YOU HAVE BEEN WARNED.
    Zip ties poked through. See how there's nothing substantial to attach them to?
    So we fab up a wooden 1x2 brace that will run across the back of the seat (inside that black cover) The two little offset legs you see are to get correct spacing from the middle two steel seat support bars, otherwise this will be in too close. This shows shape, but not final location and orientation. Note that there are holes drilled to accept zip ties for the KeriBacks, and also the zip ties that will hold this in position against the steel seat frame. You don't want it slowly sliding down the seat over time.
    The KeriBacks fully mounted. Yes the driver is a little taller, even though they're the same 14x19" nominal size. :mad:
    Reattach the seatback. That "H" contour is less pronounced now.
    Fully reattach the bottom seat cover and reattach the wiring harness at it's original mounting locations.
    Reinstalled in the cab:
  2. Apr 6, 2011 at 6:36 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    Nice job
  3. Apr 6, 2011 at 7:33 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    thanks.
  4. Apr 6, 2011 at 7:49 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    nice work, first impressions?
  5. Apr 6, 2011 at 7:50 AM
    afd23a
    The Dynamo of Dixie
  6. Apr 6, 2011 at 7:55 AM
    MartyMcfly
    MartyMcfly Time Traveler
    ROB
    Crapwater Floriduh
    15' 4runner Limited 4wd
    see Build page for details.
    Nicely done. I wish I had the patience to do something like that.
  7. Apr 6, 2011 at 9:38 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Thanks.
    I like the seatbacks-- I'd been test running one on the driver side for about a month just using the straps to hold it in place.
    Removing the rods is a good thing, but the bottom cushion is still a little squishy. If I did it again, I might put a thin sheet of plywood between the springs and the cushion on the driver side only.
    Whole thing was a "one Saturday" job.
  8. Apr 6, 2011 at 5:32 PM
    bomann22
    bomann22 Member
    Jimbo
    Tallahassee, Fl
    09 PRERUNNER SR5
    Amp and speakers. FJ Cruiser Rims K&N drop in filter.
    Awesome work!!! I have one question. Is the passenger seat weight sensor bladder outside the foam between the springs and the grey felt. Or is there like another secret chamber between the foam and the seat cover itself? Im going bench to bucket possibly and am on recon right now. any advice you could pass please be a pal and pass it on.
  9. Apr 6, 2011 at 5:39 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yes, it's below the foam. That felt protects it.
    I pretty much did not disturb it but when I touched it, it felt pretty delicate.
    Those seat support springs are strong, and gonna be a bear to remove if you're going to pull that sensor put. There may be a special spring tool you can use to open them up.
  10. Apr 8, 2011 at 8:24 PM
    canucklehead
    canucklehead Well-Known Member
    sunnyvale, ca
    05 Tacoma reg cab 4x4
    very nice! :thumbsup: to your write ups
  11. Apr 8, 2011 at 9:38 PM
    pinktaco808
    pinktaco808 Hot Steppa
    looks good man
  12. Apr 8, 2011 at 9:46 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Thanks!
    Thanks!
  13. Apr 9, 2011 at 2:27 AM
    radioactivemint
    radioactivemint Well-Known Member
    Oregon
    2011 Reg. Cab 4x4
    Thanks for sharing! Though I have bucket seats, I can certainly appreciate the hard work. Great job.
  14. Apr 25, 2011 at 8:42 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    UPDATE:
    After a week long trip with several hours of driving every day and two twelve hour road days, I'm pleased with the results.
    Cosmetically, the seat bottom now stretches out and wrinkles after a day in the saddle. But the whole thing FEELS much better. :thumbsup:
  15. Jun 8, 2011 at 3:47 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    lol i wish i lived in cali i would pay you to do this! i would totally screw something up. great job as usual excellent writeup brother!
  16. May 9, 2012 at 5:38 AM
    saaavage
    saaavage Well-Known Member
    Lancaster PA
    05 Sport QuadCab
    K&N air filter Weathertech floor mats to be continued...
    so does all this work with bucket seats?
    Hell....my legs literally hurt so bad after sitting in those gdamn seats I would EASILY pay someone to do this for me...
  17. May 9, 2012 at 6:16 AM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    Your first clue should have been the bench in bench seat. Its not lounge chair.
