BJ's wholesale Gas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco_mike73, Aug 19, 2020.
  1. Aug 20, 2020 at 9:15 AM
    #81
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    So true. MTBE might have been showing up in water, now the effects of ethanol show up in the landfill. It trashes the carbs on small engines, most of which have no parts availability - off to the landfill they go. All the cost and environmental impact to build a whole new engine.
    Biodiesel / FAME is terrible too. They failed to acknowledge fuel storage applications like standby generators. What was once 10+ years of stable diesel storage is now a year or two with biodiesel present. All they had to do was mix that same bio-oil into the petroleum up front and everything would have been a fine.
    o313 likes this.
  2. Aug 20, 2020 at 9:25 AM
    #82
    OverlandExpress
    OverlandExpress Well-Known Member
    NE Ohio
    2020 Taco TRD PRO
    When I used to run a motorcycle dyno for a living I wanted to know just this.
    I got gas from several stations in my area and made dyno runs, no real differences in any of them, HOWEVER there is no way to test the QUALITY/CONSISTENCY of pump gas from batch to batch.
    Overall pump gas is not all that different from mom and pop to big name...HOWEVER mom and pop stores are less likely to inspect their equipment or do the water/contamination testing in their holding tanks than say a bigger name vendor would.
    Now on my drag bike I use race gas for its consistency and quality, meaning from batch to batch you can rely on every batch being the same which in bracket racing everything needs to be the same as much as possible to be accurate in your run.
  3. Aug 20, 2020 at 9:26 AM
    #83
    PilotguyPA28
    PilotguyPA28 Well-Known Member
    Trip
    2020 Metallic Gray Limited
    If you don’t hear pre-detonation you’re good to go.
  4. Aug 20, 2020 at 9:28 AM
    #84
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    i have not heard any detonations....but i'm not sure what exactly I should be listening for. Never heard a "ping" in my life.
  5. Aug 20, 2020 at 9:31 AM
    #85
    PilotguyPA28
    Trip
    Basically the “rattle” or “knock” sound. If you don’t hear it then 87 is good.
  6. Aug 20, 2020 at 9:32 AM
    #86
    CoTacos
    CoTacos Well-Known Member
    Steven
    Denver, CO
    2019 White Tacoma TRD OR DCSB Prem. Tech
    DiamondBack SE RCI Armor Max Modular 14 Rack Collapsing Suspension
    Unless your engine is really messed up, I doubt you ever will. Modern engines have such sensitive knock sensors they will start pulling timing even at the slightest hint of it.
  7. Aug 20, 2020 at 9:34 AM
    #87
    Clearwater Bill
    Billy
    Largo Florida
    'Top Tier' is for the most part a marketing scam, and a good excuse for dealers to try and hide behind on fuel related warranties (aka you didn't use Top Tier did you?)
    The thing to be cautious of is stations that don't have a high rate of fuel turn over and the in ground systems are old. There is more risk of contaminants there. But if your local Costco, wawa, racetrack, you name it is a busy place, you're risk level is low.
    crackils and Taco_mike73[OP] like this.
  8. Aug 20, 2020 at 10:03 AM
    #88
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Biodiesel is another example of uneducated folks (this time celebrities like Begley) using a position of trust (some folks are like rats following the pied piper) to push their personal agendas.
    Like so many things leave it to educated and experienced professionals and you’ll have a much better outcome. Or as one friend put it, both podiatrists and neuro surgeons are MD’s. Which one do you want removing a tumor from your brain?
  9. Aug 20, 2020 at 10:12 AM
    #89
    Syncros
    Syncros Well-Known Member
    Not worth the savings for me.
    Always run top tier and keep up with maintenance intervals. Never had any fuel or emissions system issues in any of my vehicles. I live on an island, all of the fuel is shipped here in bulk. The misconception is that "it's all the same, it comes in the same barge". Yeah the base stock is the same, and it's all held in two large distribution centers. The difference is in the additives, transport and storage after the fact.
    There's almost no price difference here anyway, maybe 1 or 2 cents per litre but often no difference at all.
  10. Aug 22, 2020 at 5:39 AM
    #90
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Correct, now If I plan on going some area that may not have Shell premium (or any other major brand for that matter...it's the ethanol that I'm most concerned about...most top brands have a pretty balanced additives) I carry some kind of additive/injector cleaner around.
  11. Aug 22, 2020 at 6:14 AM
    #91
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I was recently told their adding biofuel to our heating oil. When i had my furnace cleaned the other day our furnace guy said these furnaces are getting dirtier now due to the heating oil suppliers adding biofuel to it....said its terrible making more work for them.
  12. Aug 22, 2020 at 6:29 AM
    #92
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Probably best to buy from the same station that the dealership uses when they fill the tank before you take delivery of your vehicle.
  13. Aug 22, 2020 at 7:20 AM
    #93
    Taco_mike73
    Taco_mike73 [OP] Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    :rofl:as if they told me where they filled it.
  14. Aug 22, 2020 at 7:42 AM
    #94
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    Seriously? :rolleyes:
    Taco_mike73[OP] likes this.
  15. Aug 22, 2020 at 7:46 AM
    #95
    Itchyfeet
    Itchyfeet Well-Known Member
    Top tier gas is the motor heads biggest placebo.
  16. Aug 22, 2020 at 8:03 AM
    #96
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I don’t use BJ’s, its Costco for this truck.
  17. Aug 22, 2020 at 12:42 PM
    #97
    batacoma
    batacoma Truck Wars
    Yes, if the nearest station is good enough for the dealership, the nearest station is good enough for me.
  18. Aug 22, 2020 at 1:17 PM
    #98
    batacoma
    batacoma Truck Wars
    Right? but if they ever tried to deny warranty work or make a stink about the gas you use. You can tell them that's its same gas from the same place they filled it at when they sold it to you.
  19. Aug 22, 2020 at 1:32 PM
    #99
    zoo truck
    None
    I can tell you they filled my tank at a cumberland farms just a block away.
  20. Aug 22, 2020 at 1:38 PM
    #100
    Taco_mike73
    York, PA
    Wawa was just down the street from the dealership so I'd bet they went there with mine.
