Black Crystal headlights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fibertop, Oct 27, 2009.
  1. Oct 28, 2009 at 11:12 AM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    they are doing it wrong then...if you preheat to 325, turn oven off, press headlight together and then let headlights sit in there for 10 min and then press together again when they come out, you CANNOT mess this up!! i've done several lights on various toyota vehicles, have never had a problem! toyota uses good sealant.
    ...i call operator error on the messed up ones!
  2. Oct 28, 2009 at 11:52 AM
    jonny
    jonny Betty White Edition Heep ZJ
  3. Oct 28, 2009 at 12:19 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    Bhlm on oem lights you still get a solid light with solid adjustment screws. The adjustment on those chinese bhlm light suuuuuuuuuuck because one just failed on me and my light was just bouncing up and down...
  4. Oct 28, 2009 at 12:21 PM
    jonny
    rep sent for an honest ex-ebay bhlm owner
  5. Oct 28, 2009 at 8:50 PM
    MikeyD
    MikeyD Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    so hopefully this weekend im going to try your method of re sealing the head light. Im not going to take it apart just heat take out and press back together. Right?
  6. Oct 28, 2009 at 8:56 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    This must be why the Chinese are always entertaining war with the Taiwanese. :p
  7. Oct 28, 2009 at 8:56 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    well, if yours are leaking, then i would take the time to take them apart, clean and then put back together.
    *****disclaimer - the following only works on OEM lights, those egay ones use crappy glue so it really doesnt matter what you do, they will leak! *********
    follow my previous posted instructions. when putting back together, i preheat the oven and turn off. i then take the housing and lens and push together, then place in turned off oven. i then pull out after 10 min and push together as much as i can. the warmed up sealant will seal up great and you will no longer have any problems...
  8. Oct 29, 2009 at 1:25 AM
    TacoEnthusiast
    TacoEnthusiast Active Member
    Bobby
    Wichita, KS
    05 PreRunner SR5 TRD Sport
    none, nada
    Feel like I have to respond because of flaming of these supposedly worthless lights. I did the BHLM and 1 light fogged and the other did not. I sealed with silicone and electrical tape along with reheating and pushing them back together. Besides just chalking it up to operator error sometimes after tearing the light open the seal just won't be the same. I bought the ebay lights, and while I agree that they are of less quality than the OEM lights they have worked perfectly fine. I did have to adjust the lights when I got them but they function just as well as my original lights did. I had an 05 and my lenses were pretty beat up so I decided to pick up some cheaper replacements after the BHLM went south. In the end you get what you pay for. And yes, amber side markers are required in most states but I dont think you will get pulled over for these lights. Maybe a fix it ticket after you get pulled over for something else.
  9. Oct 29, 2009 at 6:42 AM
    yosh2000
    CO
    '17 Tundra CM 5.7
    did you put silicone on before you reaheated? if you reheat and push together as i have stated, there is no way you could mess this up! in the favorite words of my co-worker..."your doing it wrong..."
    also, everyone is aware that the headlight is not a completely closed system right?! there are two breathers in the back of the lights that are open to the atmosphere....
  10. Oct 29, 2009 at 2:31 PM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    I have them and think they are great looking.
  11. Oct 29, 2009 at 6:54 PM
    Razorecko
    i'm sure for some it works but its the percentange that matters. If 3 out of 5 owners of these lights have problems fogging or alligning than its not worth taking the chance imho.
  12. Sep 4, 2015 at 11:36 AM
    urban
    urban Well-Known Member
    Illinois/Michigan
    12 DCLB sport OME lift
    305/65r17's on 17x9.5 Rotiforms Cab mount chop 4.10 gears Detroit true track OME 885's Dakars Camburg UCA's Undercover SE Weathertech liners and visors Black headlight mod Debadged Rock Blokz mudflapps (oversized)
    More than that. I just bought a can of VHT nightshade and that was like $17 I think!
    Paints gonna be atleast $10
    Plus iso and sand paper and other supplies
    Spent near $100 gettting all the stuff to do the BHLM and tint the rears properly.
