Black headlight mod question...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by matt45648, Mar 17, 2009.
  1. Mar 17, 2009 at 1:01 PM
    matt45648
    matt45648 [OP] Well-Known Member
    When stripping the headlight, there are 2 small rummer pieces... I cannot seem to get them out. Do they need taken out?
  2. Mar 17, 2009 at 1:02 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    do you mean on the back of the headlight?
  3. Mar 17, 2009 at 1:07 PM
    type o negative
    type o negative Well-Known Member
    UT
    09 Double Cab TRD Sport - White
    The circular ones? They are covering up 2 little sponges for condensation purposes. I would pull them off, I did. Try pulling them side to side untill they become loose.
  4. Mar 17, 2009 at 1:07 PM
    matt45648
    Yes. I removed all bulbs, the little screws, the rubber gasket around the main light, and the plastic cover on one of the adjustment screws. I left the adjustment screws, the little metal bracket in the main headlight hole, and these 2 mysterious rubber things...
  5. Mar 17, 2009 at 1:16 PM
    DanGer
  6. Mar 17, 2009 at 1:20 PM
    TacomaYAK
    TacomaYAK The Reel Sportsman
    League City, Tx
    08 Access Cab 4.0
    Lifted.
    i pulled them off.
  7. Mar 17, 2009 at 1:22 PM
    DanGer
    I can't picture what he's talking about. I just know that all plastic and rubber i saw I pulled off
