Black molding strips on roof
Discussion in '2nd Gen. Tacomas (2005-2015)' started by undersc0re, Mar 16, 2017.
  1. Mar 16, 2017 at 12:35 PM
    undersc0re
    undersc0re [OP] Well-Known Member
    BC Canada
    exhaust and k@n filter setup.
    I had my windshield replaced, i just noticed a couple weeks after when cleaning snow off my roof that one of the black strip moldings that go from the windshield to the back of the roof is missing, I called the windshield replacement company and they said they do not have it there and are not responsible for the piece, they would have affixed it free of charge but assume no responsibility for replacement.
    My question is should I replace it or does it do nothing to protect anything, and is for asthetics only. It looks as though it has no use but to make the seam look better where the factory attaches the roof?
    ChadsPride likes this.
  2. Mar 16, 2017 at 12:47 PM
    dziner
    dziner Well-Known Member
    Jonathan
    Harrisburg, Pennsylvania
    2014 Toyota Tacoma TRD Off-Road
    Bilstein 5100 (front) | OME 885 springs | Bilstein 5160 (rear) | OME Dakar medium leafpack | JBA UCA | Cooper S/T Maxx 265/75 R16 | ARE Z-Series topper | Renogy 100W solar panel | SnoMaster TR42 fridge | sleeping platform | Mobtown sliders | Custom Car Grills grill insert
    That piece is removed to attach the factory roof rack on the cab of the truck. I just did this last weekend. There are a few spots that are taped and painted which cover the threaded holes for attaching the roof rack. Without the molding, the tape will probably deteriorate over time. Id reckon you'll be ok for a while, but I would replace it.
    undersc0re[OP] likes this.
  3. Mar 16, 2017 at 12:53 PM
    undersc0re
    BC Canada
    Ok, I assume then they removed this piece for easier windshield replacement as the timing seems to be right. Also when you put a roof rack on is this piece discarded? The truck is a 2008 access cab.
  4. Mar 16, 2017 at 12:58 PM
    dziner
    Jonathan
    Not sure about an access cab. The front of this trim piece tucks in behind the windshield molding, however slightly. I don't see why it would have been touched to replace the windshield. Removing it is a task in that it is held on with 2-sided tape at the rear window and across the top of the roof, and metal clips toward the front of the cab.
    Here's a link to the roof rack install instructions for the Tacoma Dual Cab. You can see how they remove this strip.
  5. Mar 16, 2017 at 12:59 PM
    dziner
    Jonathan
    I held on to my roof trim pieces just in case. Though I don't foresee removing the factory roof rack. You never know when you may need something. I promise I'm not a horder.
  6. Mar 16, 2017 at 1:04 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Isn't the roof rack mounts only available on the double cabs?
  7. Mar 16, 2017 at 1:05 PM
    dziner
    Jonathan
    Good point. I believe so, but to be honest, I'm not sure. In that case, it's probably just cosmetics.
  8. Mar 16, 2017 at 1:12 PM
    undersc0re
    BC Canada
    I am sure it is an access cab, that is what they call the cab with the small rear suicide doors that only open after the front door is openned first correct?
    dziner likes this.
  9. Mar 16, 2017 at 1:14 PM
    dziner
    Jonathan
    Yep. There's no pre-drilled holes in your roof. And no option for an OEM roof rack. So you should be find without the molding. Still curious why it would have been removed, or how it was removed if they didn't do it.
  10. Mar 16, 2017 at 1:20 PM
    undersc0re
    BC Canada
    Yeah, I did not know if I should press the issue if they had not touched it. I assumed because the truck was there recently that is was their fault. I would also have to prove that fact I guess. I just will not go there again or say good things about them is all. Maybe those things fall off regularly lol.
    dziner likes this.
  11. Mar 16, 2017 at 4:15 PM
    ncguire
    ncguire Active Member
    Albuquerque, NM
    15 Tacoma TRD Sport DCLB
    Yep, I think having them come off on their own is fairly common. My truck is a 2015 and one is already coming loose
  12. Mar 16, 2017 at 6:08 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    They either took it off and just denied it since you claimed to have noticed it weeks later (can't prove they did it) or it flew off, which seems to happen once in a while, maybe they did remove to do your windshield and then didn't press it back down all the way and it flew off? Who knows.
    people regularly sell/give the double cab ones away on here if you need one since roof racks are super easy to install, but on an access cab it's going to be harder to source one since people don't regularly put holes in the roof for a rack. Dealer cost is like $80
  13. Mar 16, 2017 at 7:05 PM
    undersc0re
    BC Canada
    I think I will just leave it, seems like no big deal and I am not concerned about looking good lol. 4x4 works, it runs good, wanders and pulls every which way like a mutha since the 30000 to 50000 km mark but it works....if 2 alignment places can not figure it out cheaply then its fine, just a little unsafe for the ones not ready or used to it when they drive it lol.
    It is a little hard on fuel but other than that it seems like a good truck so far at 135000 km and the only major work I needed to do was a rear axle seal.
