black oil and soot question please help!
Discussion in 'Technical Chat' started by wireman24, Sep 13, 2009.
  1. Sep 13, 2009 at 10:28 PM
    wireman24
    wireman24 [OP] Member
    Hello
    I have a 96 4 cyl 4x4 tacoma.
    It runs perfect and has no problems that I have noticed.
    Except that I have just seen that I have some black soot around the outer edge of my tail pipe. I never see any black or gray smoke coming from the exhaust while running or even while it is being started. I then checked my oil and it is very black and the dip stick has some caked on oil on the tip. I had my oil changed 3000 mile ago. The oil level is right were it should be it is not low at all. I have not noticed any loss in power or loss in gas milage. One problem is I never change my own oil so i am not sure how long the dip stick has looked like this.
    I try to change the oil every 3000 miles but sometimes I do go over that and change it at 5-6 thousand miles
    The truck has 107,000 miles on it
    Do you think this is anything I need to worry too much about?
    Should i switch to a synthetic oil like castrol gtx?
    any advice or help would be great.
    Thanks
  2. Sep 13, 2009 at 10:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW!
    We can teach/show you how to change your oil, and the soot at the end of the pipe isnt an indicator of how the engine is...more indicative of how you may be driving, i.e., short trips, or jackrabbit start at the light ;)
  3. Sep 13, 2009 at 10:45 PM
    wireman24
    It's funny you mention short trips.
    I only use this truck to go back and forth to work which is a very short trip of about 12 minutes. So I only drive it about 30 mins a day. and only get it up to 55-60 mph for about 3 minutes of that.
    So you think that could be the cause of the black soot?
  4. Sep 13, 2009 at 10:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. When its cold, its running rich until it gets to opperating temp. So...Its probably just getting to temp before you get to your destination.
  5. Sep 13, 2009 at 10:56 PM
    wireman24
    well thats good news
    What do you think about the oil and the dipstick?
    Should I switch to a different oil like gtx?
  6. Sep 13, 2009 at 10:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Without seeing it in person, hard for me to make a call. If its as bad as you say, could be they didnt change it when uyou told them to.
  7. Sep 14, 2009 at 3:55 AM
    sriley727
    sriley727 Well-Known Member
    Aiken, SC
    08 Reg cab PreRunner SR5
    Bone stock
    Which is exactly why people should change their own oil. Put those high school kids out of business.:D
  8. Sep 14, 2009 at 4:18 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    My thoughts EXACTLY!!!!!
    His oil could be in there for 6-10K miles a time. :eek:
    Another reason to change your own oil!! Or atleast check the oil level & color immediately before & after its been changed.
  9. Sep 14, 2009 at 5:14 AM
    wireman24
    I sit in the car while they change the oil and I did see them pupme new oil into it. I am just wondering if they might not have changed my oil filter. Do you think a flush would help. If so what have you guys used to flush your engines? Do you think switching to a synthetic oil like gtx would be a good idea. I was thinking of changing the oil and then changing it again after a thousand miles just to help clean out the sludge. Do you think this will help?
  10. Sep 14, 2009 at 5:57 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    GTX isn't synthetic. Most people here use Mobil 1. Don't worry about a flush. Just continue with your scheduled oil changes. I would either change the oil myself, or provide them with the oil and filter the next time you get it changed. It sounds like are using a "generic" bulk oil also.
  11. Sep 14, 2009 at 8:14 AM
    Janster
    Jandy
    Lancaster, PA
    Although cleaning out the sludge (flush) might seem like a good idea ... with that many miles, you could actually create more problems. Hard to explain, but with piston rings/seals and all that other stuff that's been running WITH that sludge in there..... If you remove the sludge, you could create a poor running engine because things aren't seated properly.
  12. Sep 14, 2009 at 8:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sludge doesnt build around piston rings. Mostly in the top end, and crank case. FWIW, any kind of sludge in the engine is bad. A flush is never a bad thing, and moder oils have addatives to protect seals. :)
